Results 1 to 2 of 2
Thread: RPM changes Mobius XLV 2004
05-19-2007, 01:20 PM #1Junior Member
- May 2006
- 6
Reg. Moomba Mobius XLV 2004. TBI engine. I have problem with RPM changes in neutral position of Trottle. After riding and moving trottle in neutral position I have RPM may be from 1100 till 2000. If stop engine and start again i will have normal RPM. I havnt local GM or Indmar service.
Are there any ideas?
Brgds .
05-21-2007, 10:13 AM #2Brian Raymond Guest
Do you have Perfect Pass? It sounds like the servo cable is to tight, and when the engine is turned off, the servo goes to reset and your idle is okay. Also, check to see that your linkage is adjusted properly. Brian Raymond
wanted to buy 2000-2004 mobius V or XLV
By flydoc in forum Moomba ClassifiedsReplies: 0Last Post: 08-21-2007, 07:12 PM -
2004 Mobius LSV - 86 hours
By gcombe74 in forum Moomba ClassifiedsReplies: 3Last Post: 05-04-2007, 03:12 PM -
2004 Mobius LSV
By jchamlee in forum Moomba ClassifiedsReplies: 0Last Post: 08-30-2006, 05:23 PM -
2004 Mobius LSV for sale
By bcornish in forum Moomba ClassifiedsReplies: 6Last Post: 07-27-2005, 03:09 PM -
2004 Mobius
By WisMoomba in forum Boat OwnersReplies: 13Last Post: 10-21-2003, 09:50 AM
