    Nov 2019
    Default Surf Plate Settings
    Looks like my settings got reset over the winter, please remind me what setting the plates should be at. As I recall when switched to surf left , port plate at 0 and starboard around 65-70 (and vice versa for surf right)? ‘19 Helix, I have upgraded 1100 lb rear ballast and about another 2000 lbs of additional bags/lead. Also, what is a good center plate setting while surfing ? I usually keep it around 20-25.
    Feb 2018
    Boating on Lake Martin, AL
    Port on my Max is I think 65 and starboard was 70 I believe. Center setting, like surf plate settings, is all in what you like in a wave. I only use the center to clean up the face of the wave while some people use it to lengthen the wave. I prefer speed to lengthen and I don’t go over 20 for center.
    2019 Moomba Max "MOOMBAE"
    2016 Yamaha AR192 - sold
    May 2017
    Alberta, Canada
    I've followed this since Jon (SC) posted it and have had good results. WP-regular=0, WP-goofy=0-15.
    Quote Originally Posted by Jon View Post
    A Flow 2 equipped boat should come from the factory at 60/70 port/starboard. A Flow 3 boat performs really good at 45/55.
    Sorry, I'm so used to typing it like this I should have explained more. When I say 60/70 I am meaning 60% deployment of the starboard flow tab when surfing on the port side and then 70% port flow tab deployment when surfing on the starboard side. Same things for 45/55.
    Original thread is here:
    https://forum.moomba.com/showthread....690#post369690
    2021 Mojo, 6.2L Raptor 400/1.76, Acme 3407 15.5x13, G6, Flow3, +6500 lbs ballast
    2005 Mobius LSV (sold)
    Windermere Lake, B.C., 2800' Elevation
    2021 Mojo Mods
    Nov 2019
    Thanks guys this is what I thought
    Apr 2013
    Knoxville TN
    If that does not work, try calling/emailing SC.
    2018 Supra SL400
