Results 1 to 6 of 6
    Feb 2022
    Default 2019 Moomba Max Delay In Shifting
    Hello everyone!
    Apologies if this has already been talked about here. The boat shifts into reverse instantly, however, there is a 2.5ish-second delay when shifting into forward. Is this normal? No weird sounds or anything.
    Thanks for any insight!
    2019 Moomba Max
    Indmar Raptor 400
    Feb 2018
    Boating on Lake Martin, AL
    Are you referring to the amount the lever has to move before it engages or saying it’s taking more time than normal to engage?
    2019 Moomba Max "MOOMBAE"
    2016 Yamaha AR192 - sold
    Mar 2021
    South Georgia
    Funny, because my 2021 Makai takes just a second for reverse to engage. A slight push on the forward throttle almost instantly engages the drive just like you would expect. However when I do an easy shift into reverse, it takes a second to engage. No harsh sounds or hard knocks. It's smooth as can be, but it just takes a noticeable second. I just thought it was normal. Now, if I shift quickly into reverse, as I have done a few times when I was coming into my boat slip a little hot due to rain catching us. It is pretty instant. I'm not sure I have helped answer anything here. Just my observations of my boats reactions.
    2021 Moomba Makai
    Feb 2022
    I'll shift forward, then 2.5 seconds later, the prop starts to spin. Adds a bit of a challenge when docking or loading onto trailer to account for delays, haha.
    2019 Moomba Max
    Indmar Raptor 400
    Feb 2022
    That is interesting... flipped around on your boat. Thanks for sharing your observations!
    2019 Moomba Max
    Indmar Raptor 400
    Jun 2020
    Utah
    Quote Originally Posted by apf4 View Post
    That is not normal. We had an issue with that on a previous boat. It took a long time for the dealer to diagnose and correct but was a fault with the neutral selection switch. The boat wasn't sensing a return to neutral and was locking out the forward gear in the transmission. Have your dealer look at it under warranty.
    2016 Moomba Mojo Surf Edition
    2000 Sharpe Houseboat 70x16 (Lives at Lake Powell)
