Results 1 to 9 of 9
    Jun 2022
    Minnesota
    Default 2023 Max 12V Power Outlet
    Hey Guys,
    I found an old thread on 12v power source (cig lighter) in the Max, but couldn’t find anything for the current model year.
    I’ve been out in my new ‘23 Max twice now and looked around and don’t see one anywhere. My daughter is flipping out about tubing, but I really don’t want a fully inflated tube on the boat all day when we’re out. If they don’t have one, anyone have any other ideas for inflating/deflating on the water?
    Thanks!
    2023 Moomba Max
    2005 Moomba Outback (Sold)
    Salt Lake City, Utah
    I believe it is on the bottom left side of the dash, to the left of the surf switch. I think it has a cover on it.
    Scott
    2021 Craz
    1997 Sea Ray 190
    Jun 2020
    Utah
    I’ve always had better success with the inflators that clamp onto battery terminals. The one we have now can blow up a 5-person banana boat in about 3 mins.
    2016 Moomba Mojo Surf Edition
    2000 Sharpe Houseboat 70x16 (Lives at Lake Powell)
    Jun 2022
    Minnesota
    Under that cover on the bottom left of the dash is just a usb outlet and an aux cord for the stereo. Maybe I’ll have to go the route of alligator clamps straight to the battery, but i have two batteries that are sealed up in boxes.
    2023 Moomba Max
    Jan 2021
    Columbus, Ohio
    Under the port side locker is a 12v bus lug and ground lug that the amps use. They come straight from the battery switch and would be where I would clamp to for you pump.
    2015 Moomba Mojo Surf Edition
    4,000lbs
    Manual Flow
    Quote Originally Posted by NedFlanders13 View Post
    ok, sorry about that. On my 2021 Craz there is one inside the glove box. Maybe check there?
    Scott
    2021 Craz
    1997 Sea Ray 190
    Mar 2021
    South Georgia
    My 21 makai has both usb and 12v plugs on the dash, and by the cup holders usb on one side of the boat and 12v on the other. I guess Moomba changed that setup moving forward. Shame, because we did exactly what you are describing wanting to do with tubes on occasion.
    2021 Moomba Makai
    Feb 2018
    Boating on Lake Martin, AL
    IIRC My 19 Max has cigarette lighter outlet in the glove box and under the drivers dash area.
    2019 Moomba Max "MOOMBAE"
    2016 Yamaha AR192 - sold
    I have a 2023 max as well, same issue I got one of these and it does the job. https://www.walmart.com/ip/Intex-Min...CABEgJHoPD_BwE
    2023 Moomba Max
    5,550lbs ballast | 1,000lbs lead = 6,650lbs
    2014 Moomba Mojo 2.5- SOLD
    Tow- 2002 F-350 Super Duty 7.3L PSD
