In my other post I mentioned our 2010 LSV is throwing a code about pedal position sensor. Reading online this points to the sensor on the back of the throttle control that is part of the DBW system.
Upon inspection, the one on our boat is made by Kongsberg as a vsense hall effect sensor which is completely sealed and from my research over the last 2 weeks, CANNOT be purchased separately and you need to buy an entire new throttle control assembly from Teleflex marine.
With that said, has anyone had a similar code or issue and found it NOT TO BE the sensor or more of a wiring or connection problem? I haven't dug into it much as I just setup my homemade mefi 5 scanner to pull the code and find out what the issue was from the fall when the CEL illuminated on the dash.
Going to be digging into this more in the spring but want to start reading up on possible alternate causes before I shell out $500+ for a new setup.
