11-12-2022, 03:18 PM #1
DIY oil extractor for less than 20 bucks.
DIY oil extractor for less than 20 bucks, or free if you have the parts. 3d printed cap, pump sprayer, vacuum pump
Sent from my SM-G998U using Tapatalk2022 Mojo - 400 - flow 3 - OJ 930 15.5x15 prop - 1k lead - 2.5-3k elevation
previous: 2007 centurion elite V air warrior
11-12-2022, 03:22 PM #2
Cool! I like that.
Sent from my SM-G781V using Tapatalk2021 Moomba Makai
11-14-2022, 04:23 PM #3
11-14-2022, 06:02 PM #4
Yeah. I know what you mean. The one I bought from Orielly's Auto a long time ago only holds 6 qts. Just have to dump and start again!
11-23-2022, 03:30 PM #5
yep, i just used a 1 gallon one i had sitting around, plan next year is to buy a 2 gallon (8qts+)... ive seen them less than 10 bucks at walmart end of summer when they clear out stuff.
but honestly, it took less than a min to disconnect and drain the tank, you can run pressure on the vac line to empty it quickly. and since you use the extraction hose, you can fill any container easily without the mess.2022 Mojo - 400 - flow 3 - OJ 930 15.5x15 prop - 1k lead - 2.5-3k elevation
