Results 1 to 5 of 5
    May 2022
    idaho
    Default DIY oil extractor for less than 20 bucks.
    DIY oil extractor for less than 20 bucks, or free if you have the parts. 3d printed cap, pump sprayer, vacuum pump
    Sent from my SM-G998U using Tapatalk
    2022 Mojo - 400 - flow 3 - OJ 930 15.5x15 prop - 1k lead - 2.5-3k elevation
    previous: 2007 centurion elite V air warrior
    Mar 2021
    South Georgia
    Cool! I like that.
    2021 Moomba Makai
    Aug 2020
    Middle Tennessee
    Cool! I like that.
    Less than 20 bucks
    *3d printer, vacuum pump, sprayer bottle, hose and fittings not included in cost estimate and may effect total cost of product
    Gonna need a bigger container.
    My extractor is 7 qts which is super frustrating as my oil change is 8 qts.
    2020 Supra SA
    Mar 2021
    South Georgia
    Yeah. I know what you mean. The one I bought from Orielly's Auto a long time ago only holds 6 qts. Just have to dump and start again!
    2021 Moomba Makai
    May 2022
    idaho
    Quote Originally Posted by SONIC View Post
    Less than 20 bucks
    yep, i just used a 1 gallon one i had sitting around, plan next year is to buy a 2 gallon (8qts+)... ive seen them less than 10 bucks at walmart end of summer when they clear out stuff.
    but honestly, it took less than a min to disconnect and drain the tank, you can run pressure on the vac line to empty it quickly. and since you use the extraction hose, you can fill any container easily without the mess.
