Results 1 to 10 of 20
    Default Keeping Kids Warm
    What is everyone using to keep the kids warm in the boat. You know, after they come out of the water and have to keep their wet life jacket on. Then they get cold, start complaining and try their best to ruin the adults fun? 22 Mojo, no heaters. Any specia blankets or jackets that folks are using?
    TIA
    2022 Mojo
    May 2018
    Perhaps a change to a dry life jacket?
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    Life jacket is just part of it. There is also wet bathing suit, wind from the boat etc.
    2022 Mojo
    Apr 2013
    Knoxville TN
    There are several companies that are making blankets. Surfinity, Hyperlite, and Mambe - probably more.
    Works with the heater.
    Expensive.
    2018 Supra SL400
    May 2018
    You can add a heatercraft heater to your boat.
    2021 Supra SA 400
    Michigan
    Henderson, NV
    knowing it's important to keep the kiddo's engaged and excited about recreating, I'd spend a few $$ on a waterproof blanket as mjh suggests(amazon has examples for under $50) and as larry points out, my FIRST winter mod would be a heater. the few bills you will spend on it will be money well spend in the long run.
    I'd mount the heater in the observers storage rather than under the dash for more tubes on the observers side for the kids.
    you could also opt for installing seat heaters under the vinyl over the winter as well but that's much more engaged and likely more expensive than a heater but it's another option.
    I would swap lifejackets once out as my experience is a jacket will hold water/cold a lot longer than boardshorts.
    Jan 2021
    Columbus, Ohio
    Neoprene life vest - dry faster
    Store life vest in tray above engine - heats them and helps dry them faster
    Liquid force (and others) make "changer towels" they are like towel ponchos that work over the life vest.
    Close the window and use the bow filler as a block to stop the heavy breeze while moving.
    Heaters are great but costly. Being a new boat might be worth the upgrade.
    2015 Moomba Mojo Surf Edition
    4,000lbs
    Manual Flow
    Nov 2016
    Knoxville, TN
    My wife keeps an extra life jacket and a change of clothes for our little girl. She also has a towel hoodie she can put on. Our boat has a walk through wind blocker and heaters, so that helps.
    2011 Sea-Doo Wake 155
    Sep 2017
    1. Dry Life Jackets - Make a big difference!
    2. Ponchos are sweet too.
    3. Heaters are so good...my youngest constantly uses them.
    2022 SA450
    2019 Mojo
    2017 Mondo - SOLD
    Mar 2021
    South Georgia
    Get some "Snuggie's" or one of these things!
    2021 Moomba Makai
