Page 1 of 5 123 ... LastLast
Results 1 to 10 of 49
    Mar 2022
    Winston Salem NC
    Default Prototype Makai rear bags
    Got lucky to get some prototype rear bags for the Makai from WM.
    The are basically the WM rear bags + an extension (all one piece) to go under the bench seat (halfway). Some rough math = ~600lb addition over the standard WM bags. Only downside was I had to move my tube to the front of the boat for storage.
    Install was super easy. I'm considering running an extra vent off the top like many of you have done, but wanted to get an initial test before hand. I'm sure I'm still dealing with some air etc.
    How far it fills up the bench storage when full
    How it looks under corner seat when full
    Bags full ( seemed a few inches lower than before).
    Obligatory wave picture. Windy day. Small crew. Bags Full. No autowake, just 100/100/100 fill and tab 70%. Riding the wave: the push is improved and I've moved the speed from 10.4 with the old WM bags to 11.1 with these. I can ride a few feet farther back now. Still need to dial in the settings more.
    2022 Makai 400
    15.5x16.5 prop (18 back up)
    Chilltech
    Premium Wetsounds Package
    WakeMakers (custom) bag upgrade
    Jul 2022
    Alberta/BC
    Looks good, I am assessing options (as I am sure many are) as I run a small crew in a makai as well…
    To be clear, are you talking 600lb over the stock bags, or 600lb over the aftermarket bags?
    Mar 2022
    Winston Salem NC
    Quote Originally Posted by Dukabor View Post
    600 over the WM aftermarket bags. So I would say around 1200lbs over stock.
    2022 Makai 400
    Chilltech
    Jan 2021
    Columbus, Ohio
    So Enzo bags for a Makai.....sweet
    2015 Moomba Mojo Surf Edition
    4,000lbs
    Manual Flow
    Mar 2021
    South Georgia
    That's impressive, but I am not so sure how I feel about losing the space in the hinged seat area. We keep a cooler there, anchor, bumpers, and jackets etc... I was hoping it would only go slightly past the smaller corner seat. But I understand that would be less weight if it were shorter.
    2021 Moomba Makai
    Oct 2018
    Hockley, Tx
    With your boat being on the water you would be better suited to use lead in that space IMO. You could fit 600# in the space you are talking about pretty easily.
    2019 Makai
    Raptor 450 w/ 1.76 Trans
    Jul 2022
    Alberta/BC
    Quote Originally Posted by dyrmz134 View Post
    Damnnnnnnnnn Thats right about where I was thinking I needed to be…. Sweet
    May 2018
    Quote Originally Posted by TXSurf4 View Post
    I second this, lead or storage, pick one.
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    Mar 2022
    Winston Salem NC
    I agree. Unfortunately my tow rig is about maxed out and I travel to and from the water each time. So far the storage isn’t an issue, just had to relocate the tube.
    2022 Makai 400
    Chilltech
    Jul 2022
    Alberta/BC
    This feels like my dilemma as well, lots of hard mountain passes to tow over with the lakes I enjoy here, every little bit helps the tow rig, but I imagine there are many circumstances where the storage could be an issue…
    To the OP…. Any word on the prototype status? Something for next season or sooner?
    2022 Makai
    Fire Red - Pecan ChillTech - Woodgrain Gatorstep
    400 - 1.76 - 15.5x15 prop (16x13 Acme 3409 installed for testing)
    Ballast Mods: 1000lb of lead and WM Bags
