Results 1 to 10 of 13
07-12-2022, 09:45 AM #1Junior Member
- Jul 2022
- MI
- 6
06 Mobius LSV Gravity 3 ballast issue
I'm looking for some guidance; maybe someone has seen this issue before....
At the beginning of the season my ballast system filled all of the bags with no issues.
However, the solenoid valves wouldn't close properly, so the bags filled by themselves while driving fast even with all the ballast switches off.
So I replaced the solenoid valves with these........https://www.homedepot.com/p/Orbit-1-...7281/300642255
(purchased from the Moomba dealer though)
After changing the solenoid valves, I was getting a 'water hammer' effect when all ballast switches were on and the water flow to each bag was very slow, and kind of 'pulsing' and not a consistent stream. But I can get each bag to fill more easily if I fill them up one at a time.
So I went ahead and bought a new OEM ballast pump from the dealer, since it still had the original, but after installing it there was no change.
It seems like the solenoid valves are restricting the water flow, since the bags filled properly before changing them.
Thoughts?
07-12-2022, 11:28 AM #2
They are 12VDC solenoid valves, and not 24VDC? (The HD site were 24V)
Is the Polarity correct being DC?
Hammering is a restriction. Sounds like the pumps are trying to suck through the valves. That is why I am asking. Sounds like the valves aren't opening when you power them.2015 Moomba Mojo Surf Edition
4,000lbs
Manual Flow
07-12-2022, 11:45 AM #3Junior Member
- Jul 2022
- MI
- 6
I'm not sure on the voltage since I bought them from the Moomba dealer. The home depot site just looked like the same ones. I also wondered about the polarity, but the two wires are identical and both just solid black. I can feel them open with the ballast switch, and they are pumping some water, but it's like a cyclical stream of water and not consistent flow. I agree that it seems like they're not opening completely.
07-12-2022, 12:10 PM #4
There are usually flow arrows on these. However, being fill and drain from the same hose I suspect these aren't single direction.
If so, that could be the problem.
Are all 3 pumps sucking water through the same through hull fitting?2015 Moomba Mojo Surf Edition
4,000lbs
Manual Flow
07-12-2022, 12:49 PM #5Junior Member
- Jul 2022
- MI
- 6
There is one fill pump (& one through hull fitting) that feeds the 3-sprinkler-valve manifold. Then each bag has its own smaller drain pump that empties it through a separate tube. I verified all 3 sprinkler valves are in the correct orientation. I also tried manually opening the solenoids and recall it being about the same result.
07-12-2022, 02:02 PM #6
best advice I would give is to ditch the irritrol setup and move to 3 separate fill pumps but that's a larger project best suited for winter. I hated that setup on our supra but back in the day, it was the standard.
sounds like valves are not opening all the way as you indicated. do a search on here for old threads and see what others have replaced with. the oem's were irritrol not orbit iirc. could be worth trying to find the exact replacement. I don't recall voltage being an issue but the ones you were sold might be a heavier duty version that needs 24v to open properly.
dumb question but nothing stuck in the intake hoses anywhere that would restrict flow or caught in the scupper under the boat.'06 Supra Launch 20SSV-gone but never forgotten
07-15-2022, 12:11 AM #7
Good to hear.....
07-18-2022, 05:11 PM #8
Van Halen rules!
