Results 1 to 6 of 6
Thread: Kaiyen Screen not coming up
07-10-2022, 09:57 AM #1Member
- Jun 2013
- Saratoga Springs, NY
- 52
Just getting her into the lake for the summer, has been a busy year. The main screen isn't coming on. I tried to rest the main fuse but that didn't help. Any ideas I can try before I pull her out and bring her to the dealer a few hrs away? Radio, lights, and other electronics are working fine. Thank you!
- Greg2020 Kaiyen
2006 LSV- Sold
07-10-2022, 10:39 AM #2
Check any connections you can find behind the screen. Unplug and replug them back in.
07-10-2022, 08:40 PM #3Member
- Jun 2013
- 52
Went out today and it worked for half the day then nothing. Wake plate was inoperable and the switches to drain the bags didn’t work.
Any thoughts?
Sent from my iPhone using Tapatalk2020 Kaiyen
2006 LSV- Sold
07-10-2022, 08:49 PM #4
Did the radio, nav lights, horn, all stop working also?
Sounds like you keep losing ACC power. Breaker trip, loose connection at battery or any of the buss bars.2015 Moomba Mojo Surf Edition
4,000lbs
Manual Flow
07-10-2022, 09:37 PM #5Member
- Jun 2013
- 52
07-10-2022, 10:26 PM #6
They are latched on the top and bottom. You squeeze them and they will pop off.
Check the back of the ignition switch also. You could have a soft-set connector or loose wire.2015 Moomba Mojo Surf Edition
4,000lbs
Manual Flow
