Results 1 to 6 of 6
    Saratoga Springs, NY
    Default Kaiyen Screen not coming up
    Just getting her into the lake for the summer, has been a busy year. The main screen isn't coming on. I tried to rest the main fuse but that didn't help. Any ideas I can try before I pull her out and bring her to the dealer a few hrs away? Radio, lights, and other electronics are working fine. Thank you!
    - Greg
    2020 Kaiyen
    2006 LSV- Sold
    Mar 2021
    South Georgia
    Check any connections you can find behind the screen. Unplug and replug them back in.
    2021 Moomba Makai
    Went out today and it worked for half the day then nothing. Wake plate was inoperable and the switches to drain the bags didn’t work.
    Any thoughts?
    2020 Kaiyen
    2006 LSV- Sold
    Jan 2021
    Columbus, Ohio
    Did the radio, nav lights, horn, all stop working also?
    Sounds like you keep losing ACC power. Breaker trip, loose connection at battery or any of the buss bars.
    2015 Moomba Mojo Surf Edition
    4,000lbs
    Manual Flow
    Radio and nav lights were working didn't try the horn. I did find the fuse area behind the steering wheel area but didn't try to reset any. How do the covers come off?
    2020 Kaiyen
    2006 LSV- Sold
    Jan 2021
    Columbus, Ohio
    They are latched on the top and bottom. You squeeze them and they will pop off.
    Check the back of the ignition switch also. You could have a soft-set connector or loose wire.
    4,000lbs
    Manual Flow
