Results 1 to 2 of 2
05-14-2007, 09:21 AM #1Junior Member
- May 2007
- 1
WAKEBOARD PRO PROP VS STANDARD MOOMBA PROP
CAN ANYONE TELL ME HOW MUCH THE WAKE IS GOING TO CHANGE FROM THE STANDARD PROP ON A 2007 MOOMBA OUTBACK V TO THE UPGRADED WAKE BOARD PROP.
WILL I STILL BE ABLE TO SKI USING THIS PROP OR IS IT GOING TO MAKE THE WAKES LARGER AND HARDER.
ALSO WHAT ABOUT PERFORMANCE,FUEL ECONOMY AND TOP END SPEED.
THANKS
HOPE YOU CAN HELP A NEW MEMBER OF THE MOOMBA FAMILY.
05-14-2007, 10:14 AM #2Senior Member
- Oct 2005
- Central FL
- 791
Welcome dMon.
The wake of a boat is mostly determined by the hull running through the water, and not the prop. The center spray will change a bit. The wakeboard prop is mostly designed as an improvement in torque for pushing a much heavier boat through the water since it normally has a thousand pounds of ballast. You will loose top end speed, but gain hole shot.
Also:
Please find this key on your keyboard
...it seems to be stuck down. Please remedy that.
Hope this helps,
-Joe
WANTED - 14.25 x 14 Wakeboard prop
By phenom_1819 in forum Moomba ClassifiedsReplies: 3Last Post: 02-21-2008, 05:27 PM -
CNC Wakeboard Prop Upgrade
By zegm in forum General ChatReplies: 2Last Post: 01-26-2008, 10:58 PM -
Standard Prop Size on '99 Outback??
By AaronWhitt82 in forum Service & RepairReplies: 2Last Post: 10-25-2007, 10:23 PM -
wakeboard prop
By Nboard10 in forum General ChatReplies: 0Last Post: 04-10-2006, 10:22 AM -
CNC Wakeboard Prop For XLV
By 05mobiusxlv in forum General ChatReplies: 2Last Post: 08-08-2005, 07:52 PM
