Results 1 to 3 of 3
    Default Raw water pump mounting stud failure
    Hello,
    I have a 2016 Craz with the standard Raptor engine. The only problems I have had since I bought the boat new are related to the Raw water pump. About 3 yrs ago one of the brackets that support the water pump broke. Yesterday I discovered the stud bolt that mounts the bracket to the engine sheared off. I was able to retrieve the stud bolt with a 7/8” socket. The parts guy had a hard time figuring out which part I needed. Pictures help. Not sure if anyone has had this problem but I thought I would post. The part number is in the picture.
    Jan 2021
    Columbus, Ohio
    When I bought my boat second hand that bolt and the 2 bolts that mount the bracket together were all loose.
    I removed, added blue locktite, re-torqued. Has been good ever since.
    2015 Moomba Mojo Surf Edition
    4,000lbs
    Manual Flow
    Jun 2022
    White Plains, New York
    My son also had the same problem with his boat and bolt replacement helped him, but I don't know if it was the same detail or not.
    Moomba Outback V-Drive - 2010 (sold)
    Moomba Makai - 2020
