Results 1 to 2 of 2
Thread: 2001 Moomba Kamberra Kill Switch
05-11-2007, 10:29 PM #1Junior Member
- May 2007
- Georgia
- 1
Hello all, I am a new owner of a 2001 Moomba Kamberra with a Chevy 350 engine. I noticed the boat did not have the optional kill switch and was wondering if I could install myself and if so where I might find some instruction or if I should just let a pro do it? Any help is appreciated.
Thanks,
webSavvy
05-12-2007, 04:39 AM #2
Piece o cake.
Get you a kill switch like those that are the kind you want. West Marine or Boater's World (maybe Wally World, but I doubt it).
Find the 'run' wire on the ignition switch. You can do this by using a volt meter if you haven't got a wiring diagram. Mount the kill switch, sever the run wire, attach the ends to the switch. It doesn't matter which side, because all the switch does is complete the circuit.
You can test it by turning the ignition switch to the 'run' position and checking for voltage across the kill switch. Popping the lanyard off should cut the voltage.
Hope this helps
B
Moomba Kamberra
By Music in forum Moomba ClassifiedsReplies: 3Last Post: 02-19-2007, 02:07 PM -
Kamberra 2001 Prop or drive shaft SOS
By in forum Service & RepairReplies: 0Last Post: 09-04-2005, 06:48 PM -
2001 moomba Kamberra
By Gunnerb in forum Sales & InformationReplies: 0Last Post: 07-28-2003, 02:54 PM -
perfect pass on existing paddle wheel (2001 Kamberra)
By Preston Duke in forum General ChatReplies: 1Last Post: 01-13-2003, 12:15 AM -
By in forum General ChatReplies: 0Last Post: 01-11-2003, 11:41 PM
