Results 1 to 3 of 3
    Default What do I wire an amp and sub to?
    Hi all!
    I am installing an amp and sub into my 2021 Kaiyen. Do I wire it to the battery switch somehow or the battery itself?!
    Jan 2021
    Columbus, Ohio
    Under the port side dash is an amp rack. Should be 2 buss bars 1 for power and ground.
    2015 Moomba Mojo Surf Edition
    4,000lbs
    Manual Flow
    You want to insure that the new amp's B+ is drawing from the same source as the rest of the audio. I prefer to have my audio pull through the main battery switch v's battery direct.
