Results 1 to 7 of 7
    Jan 2007
    Indiana Lake IN
    Default What size ski do I need.
    I am a male 6ft 2inches tall and weigh 180 lbs. I am looking at getting the O'Brien Synchro. My question is what size. 66'' or 69" Any insight would be apreciated. Thanks
    Jan 2006
    Michigan
    Im 5'6", Buck 35 and I ride a 67 So I would suggest a 69
    Mar 2003
    s.e. washington state
    If he choice is between 66 and 69, I would recommend the 69 also. A 67 or 68 would be more suitable.
    Oct 2005
    Central FL
    What Zabooda said.
    -J
    Jan 2003
    Minnesota and Wisconsin
    Height and weight are pretty important, but you also need to consider your typical rope length and speed. If you are skiing long line, 75' and 30 mph your ski length requirements will be quite different than if you are running 32 off at 34 or 36. The faster and shorter you go, the shorter the ski you can use.
    Over the last 25 years I was 5'10 and weight ran 170 - 200 depending on year, and I was on 65 inch Connelly Shortline skiing 15 off at 30 mph for years, and only dabling with anything shorter. If fell a lot and had issues that I could not explain, and got tired fast. Over the last two years I have moved up to about 215 ( I am working on it getting that back under control). I also moved up to a 69' Connelly Concept. In a matter of a about two years I went from fighting 15 off at 30 mph, to having a lot of fun runnig 32 off at 34. There are a lot of things that can probably account for this, but I bet the right ski length had a lot to do with it.
    My guess is that O'Brien has a web site that will probably recommend the best lenght for that ski based on all of the above.
    HTH
    Dave
    Jan 2007
    Indiana Lake IN
    Thanks for the help. I think I will go with the 69
    Based on your measurements
    If you are skiing 22 off at 36 mph on the slalom course, i would go with the 66" ski.
    If you are a recreational skier with longer rope lengths and slower speed, go with the 69"
    I am a 175 lbs, 5'10". I had been skiing a 65" ski, but recently went to a 67" ski. I ski 36 mph at 22 or more off. I am doing some tweaking on the new ski this year, but if I am still not happy, I will probably go to a 66" next year.
  1. Tube Size on 08' LS
    By Hydrofoiljunky in forum General Chat
    Last Post: 03-19-2008, 12:46 AM
  2. Subwoofer size
    By cab13367 in forum General Chat
    Last Post: 03-28-2007, 11:47 PM
  3. What size amp
    By pnichol080 in forum General Chat
    Last Post: 03-07-2007, 11:01 PM
  4. Board size
    By aintskeered in forum Wakeboarding | Wakeskating
    Last Post: 08-25-2006, 10:46 PM
  5. Shaft Size
    By bryanen in forum Service & Repair
    Last Post: 10-01-2004, 09:43 AM
