Results 1 to 4 of 4
Thread: Fusion RA70NSX bluetooth issue
05-31-2022, 11:01 AM #1
anyone else having connection issues with the Fusion RA70NSX headunit? Mine will connect fine and play, but after about one power cycle on the lake it pops up with "select device to connect" even though it is still connected and playing music.
I did the latest software update per fusions website support. I dont remember if i was having the issue before or not.
At least it is still working, but it is annoying i cant see what is playing.2022 Mojo - 400 - flow 3 - OJ 930 15.5x15 prop - 1k lead - 2.5-3k elevation
previous: 2007 centurion elite V air warrior
05-31-2022, 11:22 AM #2
not sure on why that is happening, but you could wire the stereo to a extra switch and take it off the ignition. I did that and the stereo is always on even when you turn the boat on and off.
Scott
2021 Craz
1997 Sea Ray 190
05-31-2022, 11:26 AM #3
06-01-2022, 08:28 PM #4
yeah, turns out to be a power cycle issue. if power is cut and restored in less than 5 seconds it has the issue, but if i wait more than 5-10 sec. it works fine.
