Results 1 to 5 of 5
    Aug 2020
    44.3894° N 79.6903° W
    Default clear error code
    Got the boat out of storage and started it up. Immediately Diagnostic message came up “Sparkplug 8 primary open or short to ground”. Sure enough when I opened it up I could see that I hadn’t plugged it back in tightly after fogging the cylinders..... plugged it back in and all is good....expect the check engine light is on and won’t go out.
    Is there a way to reset the check engine light?
    2021 Moomba Mojo
    Mar 2021
    South Georgia
    Sometimes they clear themselves after a bit of running
    Or at least that was the case on my son's Dart. Had a check engine light code for one of the air dam louvers being out of track. Had never even heard of such, but the code reader didn't lie. After snapping it back in place, it took a couple of hours for the check engine light to go back off.
    2021 Moomba Makai
    Aug 2020
    Thanks..I just disconnected the batteries for a couple of hours. Its still in the diagnostics summary but the CEL is off.
    2021 Moomba Mojo
    Jan 2021
    Columbus, Ohio
    I think the dealer has to clear it for you.
    I have a low oil stuck in the screen from having the key in the wrong position while doing an oil change.
    2015 Moomba Mojo Surf Edition
    4,000lbs
    Manual Flow
    Jun 2020
    Utah
    You should be able to reset that yourself from inside the error screens on the boat. I inadvertently did it myself while we were in a real low oil scenario as I was looking around in the controls to try to figure out what the pressure really was.
    2016 Moomba Mojo Surf Edition
    2000 Sharpe Houseboat 70x16 (Lives at Lake Powell)
