Results 1 to 8 of 8
05-14-2022, 12:50 PM #1Senior Member
- May 2020
- Nashville
- 229
Ballast pump not working but has power
Took her out for the maiden voyage and everything is working well except for starboard back ballast pump. 2018 Moomba Mojo. It is getting power and I can here it running. I went ahead and changed the impeller and the old one wasn’t in bad shape. The pump itself has no foreign bodies in it. Where else can I check to trouble shoot why water won’t flow?
2018 Moomba MOJO
4100lbs. ENZO's, Center Tank, IBS
780lbs. Lead Wake
Raptor 400
Surf Prop: OJ 945
2019 Ford F150 FX4
5.0L V8
05-14-2022, 04:19 PM #2Senior Member
- Oct 2016
- Tims Ford Lake TN
- 453
Elementary thing but did you make sure the through hull valve is open?
2016 Mojo Surf
Raptor 400
FAE
05-15-2022, 08:33 AM #3Senior Member
- Jan 2021
- South Florida
- 274
Check for any clogs in the hoses.
05-15-2022, 09:51 AM #4Junior Member
- Apr 2022
- Oklahoma
- 22
Having the same issue but with the front / center ballast. Rear are both filling.
- are there multiple valves for each ballast?
- location of the valves on the hill? Boat is on a liftLast edited by tpjsooner; 05-15-2022 at 09:53 AM.
05-15-2022, 10:46 AM #5
There are multiple ball valves but they are usually next to each other. I can reach all of mine with the transmission dog house removed.
2015 Moomba Mojo Surf Edition
4,000lbs
Manual Flow
05-15-2022, 03:07 PM #6Junior Member
- Apr 2022
- Oklahoma
- 22
Yes, got it. They were all open. Next order of operation is to check the pump for debris and check or replace the impeller?
05-15-2022, 10:06 PM #7Senior Member
- May 2020
- Nashville
- 229
I’ll check the ball valves and the inflow ports for debris.
Thanks for the ideas. Will report back.2018 Moomba MOJO
780lbs. Lead Wake
Raptor 400
Surf Prop: OJ 945
2019 Ford F150 FX4
5.0L V8
05-16-2022, 02:43 PM #8Senior Member
- May 2020
- Nashville
- 229
Ball valves are in correct position. I did the best I could clearing the hoses and found no debri. I won’t be able to test until I hit the water again. I hoping it was just the impeller.
2018 Moomba MOJO
780lbs. Lead Wake
Raptor 400
Surf Prop: OJ 945
2019 Ford F150 FX4
5.0L V8
