Thread: 2022 Mojo Prop
04-19-2022, 04:45 PM #1
2022 Mojo Prop
Hey all. I'm planning to order a spare prop and wanting to confirm which prop I actually have. I believe it's an OJ WakePro V3 932 4 Blade 15.5" x 16.5" Propeller which in the Moomba Building would be the "General Use" prop. For some reason, most of the actual stamping on the prop has been machined off so I can't confirm. While I'm on the topic, what similar ACME prop would fit this application (looking to compare performance and cost). Thanks!
IMG_4788.jpg2022 Moomba Mojo
2013 Moomba Mojo 2.5 (sold)
Tow - 2019 Ford F150 Ecoboost
04-19-2022, 05:27 PM #2
You could go 930 15.5 x 15 to give you more holeshot or heavy weight surfing.
If you can fit 16" - go 963 (16 x 15) for surf or 913 (16 x 16.25) for general use
Your 2022 has the 1.7 Trans so no need to go 12 or 13 pitch like your old mojo.2015 Moomba Mojo Surf Edition
4,000lbs
Manual Flow
04-19-2022, 05:34 PM #3
15.5x15 is a good prop. I have that on my Makai with the 1.76 Trans and 400 engine. Give me plenty of pull with a full crew.
Sent from my SM-G781V using Tapatalk2021 Moomba Makai
04-19-2022, 05:35 PM #4
If you still have your build sheet from when you ordered or bought the boat, it will have the prop listed.
04-19-2022, 06:23 PM #52022 Moomba Mojo
