Results 1 to 10 of 15
    Mar 2021
    Question 2021 Moomba Max + Boatmate trailer - "Trailer not connected"
    I bought a new tow vehicle over the winter and when I took the boat out of storage last week, I received a "Trailer not connected" error message on the factory trailer brake. Today during lunch, I hooked up my utility trailer which also has trailer brakes, and it works as expected. My old truck, I was using a Curt Bluetooth trailer brake controller and I don't know if this is a new problem or was a problem at delivery and the Curt perhaps didn't report the error. Trailer lights, and everything else works as expected. Fuses are fine, not that I'd expect any issues since everything works on another trailer.
    What I found interesting is that my second driveway where I parked the boat has a downhill slope. I hopped out and checked all four rotors and they were warm enough that I couldn't keep my finger on there for more than a second. That tells me that the brakes were applying.
    My dealer is an hour and a half away and I'll have to leave the boat there, making it six hours of driving. I'd love to have someone say, yes this is a simple fix to save the trip. Does anyone have any ideas?
    '21 Moomba Max
    May 2018
    When I got my 21 Boatmate to a 21 F150, the connection flaked out.
    My dealer had me spray WD40 on the trailer plug, plugged it back into the truck connector and has worked fine ever since.
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    Mar 2021
    South Georgia
    WD40 and Duct Tape! Ya just can't beat em!! LOL!
    2021 Moomba Makai
    Mar 2021
    Thanks everyone, I'll give the WD40 a try.
    I should really keep a can in my truck, still finding useful things to put into the Ram boxes!
    '21 Moomba Max
    Mar 2021
    Quote Originally Posted by shaggymatt View Post
    No luck with the wd40.
    '21 Moomba Max
    Apr 2020
    Prince George Canada
    My F150 was giving me a similar message. Turned out the hitch wiring on the truck was missing a relay.
    2020 Moomba Mojo
    2008 Mastercraft Prostar 197 40th Anniversary
    Owner Ness Lake Watersports
    Wakemakers “Exact Fit” Bags + Lead = 4,700 ballast
    Audio by Wetsounds, MTX, JL Audio, Clarion
    15 X 13.00 ACME prop
    May 2018
    Can you share what your tow vehicle is?
    Perhaps a bent pin not making contact? Blown fuse?
    2021 Supra SA 400
    Michigan
    Aug 2021
    Knoxville
    My ford even though its ancient had a factory 4 wire. When I changed it to a 7 pin that used the factory wiring at the back of the truck I had to add relays and a fuse to make it work.
    2019 Craz
    OJ 950
    Wakemakers bags
    Heatercraft triple heater
    Mar 2021
    It's a 2017 Ram.
    My tandem axle car hauling trailer with electric brakes works fine, it's not an issue with the truck.
    '21 Moomba Max
    Jun 2020
    Reno, NV
    It's a 2017 Ram.
    Just because the electric brakes work on one trailer doesn’t mean that either trailer, or your truck are wired correctly. I found this out the hard way. I had two different brand new travel trailers hooked up to one of my trucks on the same day. Lighting was wonky on both, and brakes worked on on, but not on the other. Hooked both to friends truck, and lights worked right, but braking issues swapped.
    After lots of circuit testing we figured out that my truck had the wrong relay, braking circuits were miswired in one trailer, and a short in the harness on the other.
    Truly aggravating day when the assumption is that factory and dealer installed options weren’t put in correctly.
    Making my new SA build come true!!!
    2020 SA 450 Wife calls it White Cloud. Said it makes her feel "Classy"
    2017 Sanger V215sx. We call it Viagra because it's the little blue pill that gets everyone up (Sold)
