Results 1 to 7 of 7
05-07-2007, 08:59 PM #1
325 FI Hesitates when taking off under load
My 2007 Outback DD runs great and takes off like a bullet with no skier or boarder in tow. About 80% of the time when I am pulling someone, when I increase speed at take off, the RPMs get to 3000 and the engine hesitates back down to 2000 RPMs for about 1-second, then takes off the rest of the way normally. Most wakeboarders survive this hesitation, no slalom skiers that I ski with can survive it.
I brought up the issue at my 20 hours service. The dealers I bought it from are awesome guys and they even allowed me to witness the service as well as them putting the diagnostic probes to the laptop and I received a printout of all the diagnostics checking out correctly.
Since this engine is not carbeurated, I am guessing that there is something up with the standard cruise control or the throtle by wire system (either way with the throttle system). Any suggestions or anyone that has experienced this and can help me to explain it better to the dealer would be greatly appreciated.-Jay
2008 Supra 21V
05-07-2007, 11:00 PM #2Senior Member
- Aug 2006
- Millington TN
- 204
Re: 325 FI Hesitates when taking off under load
Originally Posted by cptmoomba
Engine Nut
05-08-2007, 11:32 AM #3Senior Member
- Oct 2005
- Central FL
- 791
Does it happen with the cruise turned off ?
-J
05-09-2007, 05:13 AM #4
There might be some play in the cable.
B
05-09-2007, 10:48 PM #5
It does it with the cruise off.
The dealer is going to come out with his diagnostics stuff. Hopefully it is warm that day, cause the only way I can reproduce the hesistation is to tow a skier.
Thanks for all your input. Once they figure it out, I'll post the cause/result.-Jay
2008 Supra 21V
05-10-2007, 11:27 PM #6
Again, thanks for your input. Engine nut was right on. With no load (in tow) the pressure stayed at 60 psi. With my little fiance in the water in maintained 60 psi. With my XL neighbor, it dipped to 30 psi around 3000 rpms.
Took the fuel filter off and the dealer found some glue in it. Eventhough I don't understande the whole load, fuel, and ratio things, once we changed it out. We were unable to reproduce the hesitation.
And I did not expect to see a 1/2 inch filter on that boat, but in case anyone else thinks they can get by with less, the answer in no you can't.-Jay
2008 Supra 21V
05-12-2007, 12:28 AM #7Senior Member
- Oct 2005
- Central FL
- 791
Glad to hear the problem is solved.
-Joe
TAKING ON WATER !!!
By Tech Madnesss 72 in forum Service & RepairReplies: 1Last Post: 07-17-2007, 10:26 AM -
Taking on water
By BensonWdby in forum Service & RepairReplies: 12Last Post: 08-30-2005, 09:21 PM -
acc. switch load?
By dprime in forum Service & RepairReplies: 3Last Post: 09-22-2004, 05:47 AM -
Taking on Water
By Jmo in forum Boat OwnersReplies: 3Last Post: 03-25-2004, 06:52 PM -
Platform max load
By noneya in forum General ChatReplies: 4Last Post: 09-26-2002, 01:51 PM
