Results 1 to 9 of 9
Thread: leaking part
    Jan 2006
    Jacksonville, FL
    Default leaking part
    On my 98 outback on the passenger side of the engine there is a hose that i believe comes from the water intake on the bottom of the boat. It then goes into a piece of metal which i am not sure of what it is. There is a small but on the bottom of this that is leaking. I tried to tighten it with no luck of the water stopping.
    MA
    From the description, I am guessing that is the transmission cooler that is leaking. Which motor do you have?
    Jan 2006
    Jacksonville, FL
    Default here is a link to a couple pictures.
    I believe it is the transmission cooler. There is a bolt on the bottom and that is where it is leaking. I tried to tighten it but that did not help. Any suggestions.
    Jan 2006
    Jacksonville, FL
    Default sorry
    Here is the link. I forgot to post it. http://good-times.webshots.com/album...ost=good-times
    Mar 2005
    t-town
    outback, i think you trans cooler is probably toast. you can either call your local dealer or check with skidim for a replacement.
    are you talking about the small drainage nut? if so undo it apply some pipe compound and screw it back in....should not be leaking while engine is running as this is a suction line
    Jan 2006
    Jacksonville, FL
    Default Will check tonight
    Thanks
    I will take it out tonight and put it back in with the pipe compound. Hopefully that will fix it. It is the bolt that is on the bottom.
    Feb 2006
    Fayetteville, GA
    Default Re: sorry
    Quote Originally Posted by 98outback
    As a side note, that Monster Tower looks great on the boat.
    Be sure to send monster some photos, either on the water or off, to throw in their gallery.
    Jan 2006
    Jacksonville, FL
    removed the bolt and put some pipe compound on it. That fixed the problem. Thanks for the help. Also thanks for the comment on the tower. I still need to get some new decals for it.
Similar Threads
  1. part #s
    By jubal413 in forum Service & Repair
    Last Post: 05-15-2007, 05:42 PM
  2. ???Gas leaking out of Gas Cap???
    By 04OUTBACK in forum Service & Repair
    Last Post: 03-31-2007, 08:13 PM
  3. Oil Filter part number
    By RC4 in forum General Chat
    Last Post: 06-14-2006, 09:59 PM
  4. Oil Filter Part #....
    By lowerd96 in forum Service & Repair
    Last Post: 05-24-2005, 11:48 PM
  5. Part number
    By Mainemoomba in forum Service & Repair
    Last Post: 10-24-2003, 10:55 PM
