Results 1 to 9 of 9
02-22-2022, 07:52 PM #1Member
- Aug 2016
- 63
Amsoil a substitute for the Delvac 50?
Just wondering if this is a direct substitute for the Delvac 50/Indmar 50 V drive fluid? The Delvac 50 and Indmar 50 are hard to get here but I can get the amsoil easily.
https://www.amsoil.ca/p/sae-50-long-...ssion-oil-ftf/
02-22-2022, 09:45 PM #2
Amsoil SAE50 works
Sent from my iPhone using Tapatalk2021 Supra SA 400
2018 Supra SA 400 (SOLD)
Michigan
02-23-2022, 09:33 AM #3
Found delvac sae 50 at summit racing for $43/gal and Amazon for $55/gal.
Certainly cheaper than amsoil.
Michigan
02-23-2022, 09:52 AM #4
For our Vdrive Indmar sent me Mobile SHC 630 as a replacement oil to use since the Indmar oil was backordered.
2021 Makai
02-23-2022, 12:27 PM #5Member
- Aug 2016
- 63
06-12-2023, 09:18 PM #6Junior Member
- Oct 2010
- 14
RUGER761,
Did you notice any difference in running Mobile SHC 630 in your Makai?
Thanks,
Shawn2022 Moomba Makai
Raptor 400
06-12-2023, 09:27 PM #7
06-12-2023, 09:39 PM #8
Delvac 50 is readily available again
Michigan
06-13-2023, 11:20 AM #9Junior Member
- Oct 2010
- 14
I went down a rabbit hole, and I no longer believe Delvac 50 is their preferred fluid. The Malibu thread linked below started it, but I also noticed a part number change in the manual around ~2018, which aligns with the info in the thread. Also, the Bakes Marine product description for the fluid listed in the manual notes a replacement for Delvac 50.
The cost differential is close enough that I'll likely use the Indmar product, but I would guess it's a rebrand of the 630...
Malibu Form Post:
http://www.mbboatowners.com/index.ph...2-v-drive-oil/
Bakes Product Listing:
https://www.bakesonline.com/indmar-s...oil-quart.html2022 Moomba Makai
Raptor 400
