Results 1 to 10 of 17
Thread: Factory speaker issue
05-02-2007, 01:08 PM #1Member
- Oct 2004
- SE MI
- 31
I have a 03 Outback and I noticed in the fall that I had a speaker basically ready to fall apart. All 4 screw locations cracked and broke. On the speaker, not the boat. I have never taken 5 of the 6 speakers out ever. Just wondering if anyone has had similar issues. Did Moomba replace the speakers? Any good ideas on aftermarket marine speakers?
05-02-2007, 03:06 PM #2
Do yours look like this?
My boat came with those surface mount gray speakers and I had one of them crack all four corners and it rattled around a lot! A few others cracked and looked bad so I replaced them all. The sound difference is incredible!! I did not realize how bad those speakers were. Check out the links in my signature for the install.15 Mondo Surf Edition
02 LSV - Traded In
05-02-2007, 06:01 PM #3Member
- Oct 2004
- SE MI
- 31
Those are the same speakers I have. So, bottom line, buy 6 new speakers.
05-02-2007, 08:32 PM #4Senior Member
- Feb 2004
- 168
I replaced mine with Infinity 602M they sound much better than the factory speakers. They also fit the same holes.
http://www.techronics.com/index.cfm?...FQGPWAodkkZeUw
05-02-2007, 09:27 PM #5Senior Member
- Jun 2006
- 194
Wake master
Were you able to use these infinity speakers without having to make the larger rings like JesseC?
05-02-2007, 11:06 PM #6
DeepCove, the infiniti speakers from what I have been told are almost a direct replacement. They are "Top Mount" just like the factory ones. I used the Polks because I wanted to match my tower speakers. I have also read that some of the members here have fit the 6 3/4" speakers. It seems like they cut different size holes in the different years. I tried the 6 3/4" but they would not fit the front. Good luck.
02 LSV - Traded In
05-03-2007, 09:43 PM #7Senior Member
- Sep 2005
- Austin, Tejas
- 491
those stock speakers are garbage, you will be much happier if you replace them
05-09-2007, 09:49 PM #8Senior Member
- Feb 2004
- 168
THe infinity speakers are a perfect fit.
05-10-2007, 03:41 AM #9Senior Member
- Mar 2004
- Martinsville,Indiana
- 213
Those factory speakers are aweful.I replaced them with these.
http://www.crutchfield.com/S-x4uNfY7...7DB650&g=52000
they sound great.my factory speakers pulled through like that also.
05-10-2007, 01:48 PM #10Member
- Oct 2004
- SE MI
- 31
Did these speakers fit the stock speaker diameter? Do they sound good?
Tower Speaker Issue
By TN_Boarder in forum General ChatReplies: 2Last Post: 07-03-2007, 12:53 PM -
06 Mobius LSV carb issue?
By RPE_LSV in forum Service & RepairReplies: 4Last Post: 07-28-2006, 03:27 PM -
Speedometer issue
By weirdo0521 in forum General ChatReplies: 0Last Post: 05-31-2006, 12:07 PM -
speedometer issue
By patrick37 in forum General ChatReplies: 4Last Post: 11-27-2004, 08:30 PM -
speedometer issue
By patrick37 in forum General ChatReplies: 1Last Post: 05-28-2004, 12:34 AM
