Results 21 to 30 of 31
    I have a 2019, and it doesn't fit 17 i can tell you that. but i have had 4 adults and 3 kids on my mine and that was fine. Kind of depends what you are doing..
    that being said, its a great boat. Not the biggest out there obviously but for a smaller crew it works out. Not to mention easy to tow, easy to launch, easy for the wife to drive while i surf etc...
    Henderson, NV
    It is rated to hold 17 people.
    no way I would spend ANY time on a mondo with 17 on board. that might be what it's "rated" at but that would be a miserable day on the water imo.......
    spent quite a bit of time on one and 5-6 in the cabin and 2 in the bow was comfortable.
    Jun 2018
    Lay Lake, AL
    most we carry is 11 people in previous boat. Was looking at a max, but since the major Price increase looking at different options.
  4. #24
    Mar 2021
    South Georgia
    17 would be sitting cheek to cheek for sure. I have a Makai rated at 18, and have had 18 on it. Not good for anything but a tour boat when you fill it up with that many. Just way too crowded. I couldn't imagine that many on a smaller boat! Maybe if they were all 10 or 12 year old kids it wouldn't be too crowded.
    2021 Moomba Makai
  5. #25
    Salt Lake City, Utah
    yea, "rated for 17" does not mean you should take 17, that is for sure. 10-12 is the max i would take depending on if they are adults or kids. For us 7-8 is a great size with plenty of room. Anything over 10 is FULL and gets a little uncomfortable.
    Scott
    2021 Craz
    1997 Sea Ray 190
  6. #26
    May 2018
    The Mondo is 18 inches longer and 5 inches wider than your LSV. It is rated to hold 17 people. It is a much bigger and deeper boat than your LSV was.
    The latest mondo is rated for 13 people.
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
  7. #27
    oops, my bad. I was thinking the Mojo
    Scott
    2021 Craz
    1997 Sea Ray 190
  8. #28
    Apr 2013
    Knoxville TN
    17 peeps on a Mondo . . . ha ha . . . it would look like those old school pics of a listed boat with water up to the rub rails and people hanging all over the place.
    2018 Supra SL400
  9. #29
    Oct 2020
    Alberta, Canada
    We have had 11 (adults/teenagers) in our 2021 Mondo and that was pushing the limits of what we could "comfortably" fit.
    G6 is a must in my view, even with the 6 pumps it seems to take quite awhile to fill 100%.
    I thought I saw somewhere that the 2022's were only coming with the 7" screen. Notwithstanding, get it! As others have said, this is the only place to see speed, rpm, engine temp, oil pressure, depth, ballast level, and any other vital information. This is not where you want to try to save money.
    We have the removable seat back for the sliding seat. it stores under the seat itself, so is not an issue. Bottomline - we used it once, and it did improve comfort for those sitting there, but it really limits movement around the boat.
    We also have the rear storage bins - they are good for throwing wet stuff in to keep it out of the boat, but they do make bleeding air from the rear bags a bit more challenging. We now have it figured out, but it took some time. This is a preference thing, but we like them.
    2021 Moomba Mondo
  10. #30
    Mar 2021
    South Georgia
    QUOTE"We also have the rear storage bins - they are good for throwing wet stuff in to keep it out of the boat, but they do make bleeding air from the rear bags a bit more challenging. We now have it figured out, but it took some time. This is a preference thing, but we like them."
    I have the storage bins too and agree they are great for throwing ropes and vests in. Especially wet. They do have a removable round plate in them with a latch you can pop out to access your bleed valve. And after you move everything you have stored on top of it, pop it out, twist your hand and wrist around backwards to stick through the hole, and hold your tongue just right, you can bleed the air! I think a larger flip up rectangular access port in the bottom of the tray would be better, but it works.
    2021 Moomba Makai
