    Apr 2014
    Owensboro, KY
    Default Factory Moomba Cover
    Does anyone tow with the factory Moomba Cover?
    Aug 2009
    Richfield, WI
    I do on longer trips (towed several times 500 mile round trip)...no problem. Wrap the upper area with shrink film. Ratchet nice and tight.
    For me fuel economy is about 3-4 mpg better with cover.
    2021 Moomba Max
    Feb 2018
    Boating on Lake Martin, AL
    Same here for longer trips. Making sure the cover is super tight and you should be fine.
    2019 Moomba Max "MOOMBAE"
    2016 Yamaha AR192 - sold
    Salt Lake City, Utah
    i do on long and short trips. No problems so far. Just make sure you have it nice and tight.
    Scott
    2021 Craz
    1997 Sea Ray 190
    Mar 2020
    MN
    Do you keep the support pole in the bow as well or take that out?
    2021 Supra SA 400
    2018 Moomba Max - Wakemakers upgrade ballast kit (Sold)
    2005 Four Winns 170 Horizon (Sold)
    Jan 2021
    Columbus, Ohio
    I do not tow with the poles. I just use the rope on the tower. Short trips to the lake are no issues.
    The long trips I wrap the rub rail with 24" wide plastic wrap. 3 times around then pull the cover nice and tight, again no poles. The cover suctions to the boat at 55mph+. Even driving through hard rain the cover didn't pool in the bow. I get way better MPG towing also.
    2015 Moomba Mojo Surf Edition
    4,000lbs
    Manual Flow
    i don't ever use the pole, just the ropes attached to the tower
    Scott
    2021 Craz
    1997 Sea Ray 190
    Mar 2021
    South Georgia
    I never use the poles either on my Makai. Water never ponds. Just snug up the two ropes nice and good. You may need to bundle up the excess rope and put some zip ties on them to keep them from flapping all around in the Wind.
    2021 Moomba Makai
    Jan 2018
    Lexington, KY
    I only tow with the cover when I absolutely have to (raining on the highway). I tow about 100mi on backroads (55mph, not interstate) each way every weekend.
    I added one of these amazon caps to the factory support and use it in the bow:
    https://www.amazon.com/Boat-Cover-Su...390657&sr=8-26
    it spreads the load out enough that I've never had a problem.
    Towing with the cover I definitely end up seeing some light chaffing that shows up in the blue and graphite colored sections above the rub rail on the bow of my boat. These easily wax out - believe it's just in the wax, not even really in the gel.
    I agree on other's comments on MPG. Definitely better with the cover.
    2018 Moomba Craz | Autowake 2.0, Zero-Off, G6 Pumps | Captain Blue/Dark Graphite/Silver Flake | Enzos + Lead
    Feb 2018
    I tow with the pole in the bow and the hang tyte ratcheted tightly in the cockpit. The pole helps prevent the cover from fishing in on itself once the wind hits it. You can also use a large beach ball to help with that. The pole clamp isn’t the strongest and will wear out in my experience, so a beach ball is better.
