Results 1 to 10 of 12
    Salt Lake City, Utah
    Default Does your drivers seat move up and down easily?
    My 2021 Craz with an adjustable seat really doesn't move up and down much at all. I might get a few inches of movement up and down and even then it does not move easily at all. I really have to push and pull it to get it to budge. It slides forward and back and swivels just fine but not up and down. Does anyone have the same issue? Just wondering wondering if i need to bring it in to the dealer.
    Scott
    2021 Craz
    1997 Sea Ray 190
    May 2021
    Pittsburgh, pa
    Hi Scott,
    Yes, I have a '21 Craz and have the same issue. I'm taller so I would like to sit higher than I am, but its very limited in range. It's something I am looking to address over the winter. I seem to recall somewhere on this forum that you can order an aftermarket pedestal to make it taller. It's suppose to be really easy to change out.
    Moomba Craz ‘21
    Barefoot Nautique ‘91 (traded-in)
    Henderson, NV
    most of the seat hardware comes from garelick. I was looking at replacing the pedestal in our last boat with a swivel and they came up as both tige and skiers choice oem's on a lot of the pieces/parts.
    fyi...
    Jan 2021
    Columbus, Ohio
    I did the same at the beginning of the season. Wife and I are both average height humans but I don't like having to sit on the flip up every time I drive, so I replaced our with an adjustable 12"-17". Truthfully, once we set it at 15" compared to the factory 9" we have never moved it. I can sit comfortable and see well without the flip up and the wife can look thru the wind screen cruising or use the flip up and see over it while towing.
    Takes 10-15 minutes to swap out.
    2015 Moomba Mojo Surf Edition
    4,000lbs
    Manual Flow
    This is what I used for my 2017 Craz, think I cut a few inches off.
    Garelick/Eez-In 75532:01 Ribbed Series Fixed Overall Height Pedestal - 18" https://www.amazon.com/dp/B0000AXOJX..._2Mne22rSa7kLJ
    2006 Moomba Mobius LSV - Sold
    Thanks for all the responses guys, sounds like the oem is just not very good. I will look at getting a longer one then over the winter.
    Scott
    2021 Craz
    1997 Sea Ray 190
    So you prefer 15" over 9"...
    2018 Supra SL550 with 850lbs of lead wake
    2017 Supra SA400 (Sold)
    2016 Moomba Mojo Surf Edition (Sold)
    2017 Ford F250 Super Duty (Sold)
    2019 Ford F250 Super Duty (Sold)
    2021 GMC Denali 2500
    Soulcraft Vodoo
    Soulcraft Jordi Pro
    Soulcraft Super AV
    Phase Five Matrix
    Jan 2021
    Columbus, Ohio
    Does your have a locking pin and the knob to tighten it down?
    My replacement has both and holding the pin out while pulling the seat up at the same time is a pain. But once I set it, it has not moved since.
    4,000lbs
    Manual Flow
    I'm not sure about the locking pin, i don't recall fooling with that. I'll have to take a closer look at that.
    Scott
    2021 Craz
    1997 Sea Ray 190
    Jan 2021
    Columbus, Ohio
    This is the one I am talking about.
    https://www.go2marine.com/Blue-Water...y=1&height=214
    4,000lbs
    Manual Flow
