Thread: Prop shaft
    Default Prop shaft
    Hey guys and gals,
    I picked up a 2021 mojo at the end of the season and just did my winterization using the bucket of antifreeze plumbed into the sea strainer method, ran for a few minutes until the antifreeze came out the exhaust.
    Question is…I noticed a lot of antifreeze was coming out of where the prop shaft goes through the hull and into the transmission. Where the seal is I’m guessing..? For a 2021 with 50 hours does that seem normal? I did end up getting antifreeze come out of the exhaust eventually but I would say 50% came out the prop shaft area and the other 50% out the exhaust.
    Any thoughts?
    May 2018
    Are you sure it wasn’t coming out the intake grate?
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    I had the intake valve closed, nothing was leaking out until I fired it up..
    May 2018
    Quote Originally Posted by Craz16 View Post
    Ok good, then all you are seeing is the water cooled prop shaft. Normal.
    2021 Supra SA 400
    Michigan
    Okay great, thank you. That makes sense now.. just wanted to make sure i didn’t have a blown seal or something.
