Results 1 to 8 of 8
    Sep 2021
    Anderson, SC
    Default bilge pump issue
    Greetings all, I recently purchased (two months ago) a 2001 Moomba Outback to get me thru this season and the beginning of next until I order and take delivery of a 2022 Craz!
    Either my battery died or the auto bilge fuse burnt out which had my boat take on a lot of water while docked. Everything now is running great except the auto bilge. When I manually flip the switch on and off (when the float should have engaged the auto bilge) the pump will recognize the excess water and run until dry, as it should. But it will not cut on on its own. Has anyone encountered this problem before?
    Mar 2021
    South Georgia
    Sounds like the float is not working right. Could be a small piece of trash in it.
    2021 Moomba Makai
    Mar 2003
    Springfield Missouri
    The auto feature starts operating at a higher water level than if you operated it manually. I'd fill the bilge to cover the pump base and see if it turns on. Also check the pump for any debris and remove the pump cartridge and check there also. You can check for power at the pump.
    1998 Mobius
    310 HP PCM
    SOLD
    Jul 2013
    Cedar Falls, IA
    Could be the float / auto activation switch on the pump itself as was mentioned or could be the auto bilge fuse. The auto bilge fuse is different from the manual bilge switch (2 separate circuits). I've been lucky enough to experience both of these failure modes in the past 2 years on my 13 Mojo. Good suggestions above to clean things up and run a test yourself as well.
    2022 Moomba Mojo
    2013 Moomba Mojo 2.5 (sold)
    Tow - 2019 Ford F150 Ecoboost
    Sep 2021
    Anderson, SC
    Water was about ankle deep in the boat so that is why I think it might be a defective timer.
    Mar 2021
    South Georgia
    A stuck float will let it get that high too. I would check that out first. Start with the Simple eliminations.
    2021 Moomba Makai
    Jan 2021
    Columbus, Ohio
    The separate fuse holder is installed next to the battery. I found out the hard way also.
    The Attwood bilge pump has a tester on it that manually rotates the float to the up position to see if it turns on.
    2015 Moomba Mojo Surf Edition
    4,000lbs
    Manual Flow
    May 2003
    south east michigan
    My 03 Outback ls has a seperate fuse under the dash on the left side for thr automatic function on the bildge pump. It is one of the older style glass fuses.It blew once when my boat was fairly new when a small piece of fiberglass got stuck in the pump.
    jy
