Results 31 to 33 of 33
Thread: All gauges quit
10-16-2009, 07:38 AM #31
Controller is a black box about 7x9 by 1 inch thick, mounted on the 'firewall' under the dash in the upper left hand corner. I bet your hour meter does not actually work. It probably displays, but does not gain any time. If you find your speedometer lines and follow them back to the dash, you should find that they don't go to the dash, but rather to controller. If you get the controller off and shake it - you will probably hear water....
10-16-2009, 08:54 AM #32Senior Member
- Sep 2009
- Pensacola, Fl
- 163
I will check this out this weekend and report back. The hour meter definately works.
03-15-2010, 11:24 PM #33
Same thing here... 99 Outback with guages that don't work, but the hour meter is working and gaining time. However, my switches for ballast control and bilge etc etc etc. are also faulty. When they don't work you can hold the breaker down and they start working even though the breaker wasn't thrown. Seems like loose breaker panel. Is there a rewiring in my near future or is this all related to the MDC?
Blower quit
By jglasson in forum Service & RepairReplies: 2Last Post: 05-29-2007, 08:13 PM -
all my gauges just quit
By yzblue125 in forum Service & RepairReplies: 4Last Post: 06-08-2006, 03:06 PM -
Instrument Gauges
By hammons0814 in forum Service & RepairReplies: 4Last Post: 09-13-2004, 12:02 AM -
Speedometers/Gauges
By mikeoc in forum Boat OwnersReplies: 7Last Post: 06-26-2003, 09:06 PM -
Beede Gauges
By Retirement Fund in forum General ChatReplies: 4Last Post: 02-13-2003, 01:35 PM
