Results 1 to 10 of 14
Thread: 2022 Mojo Gas Gauge
08-22-2021, 09:09 PM #1Member
- Jan 2021
- 42
2022 Mojo Gas Gauge
My gas gauge consistently shows 92% when I know the tank is full. Does anyone else have this problem? Any way to recalibrate?
Sent from my iPhone using Tapatalk2022 Mojo
08-22-2021, 09:38 PM #2
Probably like this on purpose.
This way when you are at 0% it's actually 8% and you can make it back to the dock.
Most new vehicles do the same thing.2015 Moomba Mojo Surf Edition
4,000lbs
Manual Flow
08-22-2021, 09:46 PM #3
08-22-2021, 10:47 PM #4
I have found that the gas will click off only to find out that if i am patient and add some more slowly i can get a couple of 2-3 more gallons before it shuts off again. If i do the same thing and slowly add more i will get another 2-3 gallons. I can usually get at least 7-8 extra gallons after the initial shut off. My gas gauge will usually show about 98% but never 100.
Scott
2021 Craz
1997 Sea Ray 190
08-23-2021, 08:09 AM #5
I can get about 94%
Josh
2021 Mojo, Sold 7/15/22
2023 Supreme S240, on order
08-23-2021, 08:29 AM #6Member
- Jan 2021
- 42
I guess it just is what it is. There is something about dropping $250+ on a tank of gas and not seeing that damn gauge show 100% haha
Thanks for the responses.2022 Mojo
08-23-2021, 09:08 AM #7
It can also depend on the angle you're sitting when you fill up and when you look at the gauge.
if you're filling with the bow even slightly downhill it will never get full because the vent is in the back so you end up with an air bubble in the front.2020 Supra SA
08-23-2021, 10:09 AM #8
One thing I miss on the vision screens is the % full.
Sent from my iPhone using Tapatalk2021 Supra SA 400
2018 Supra SA 400 (SOLD)
Michigan
08-23-2021, 01:31 PM #9
I only get to about 80%. One thing that bugs me is that the boat goes into a limp mode when you are really low on gas and it won't allow the RPMs to come above a certain level in order to save gas. For us, it is in the surfing RPM level, so you could continue surfing just fine, but when it comes time to go get gas, you are left with a 15 MPH max speed to get back to fuel. When you know you have 20% of your tank left, it would seem there ought to be some owner's discretion.
2016 Moomba Mojo Surf Edition
2000 Sharpe Houseboat 70x16 (Lives at Lake Powell)
08-23-2021, 02:24 PM #10
I have not noticed/did not know the engine goes into limp mode when you are low on gas. I have had mine down to 0% for 20 minutes heading back to the marina and figured i was going to run out for sure. I was able to put in 55+ gallons in my tank (holds 59 gal) so i figured i was almost completely empty and did not get any limp mode.
Scott
2021 Craz
1997 Sea Ray 190
