Results 1 to 10 of 14
    Sep 2017
    Default Cruise Issues - 2019 Mojo
    Hey all,
    My 2019 Mojo is struggling with Cruise Issues this year. I thought I had Zero Off(as the screen says so)....but don't see a puck infront of windshield...so must be Paddlewheel. Here is the behaviour:
    1) Adjusting the speed constantly on outings to get proper surf speed.
    2) Seems to change based on wind direction too.(Assuming current through paddlewheel)
    3) Goofy runs almost 1MPH quicker than regular while surfing.(But with speedometer app on my phone it is the same speed)
    I am just not sure where to start troubleshooting this...so looking for any guidance.
    Thanks!
    2022 SA450
    2019 Mojo
    2017 Mondo - SOLD
    Sep 2017
    I also seem to get lots of surging while the chop is a little bigger(especially on goofy surf)
    2022 SA450
    2019 Mojo
    2017 Mondo - SOLD
    Aug 2020
    Middle Tennessee
    Surging is sometimes a result of not enough prop for the weight you're pulling.
    2020 Supra SA
    Sep 2017
    i am only running 4200 lbs of weight with a 15x13 prop....RPMs are only at 36-38 RPMs....so not sure it is the prop
    2022 SA450
    2019 Mojo
    2017 Mondo - SOLD
    Nov 2016
    Knoxville, TN
    O Off is paddlewheel, not GPS. If you are really loaded up and listed to the surf side, you're pulling the paddlewheel out of the water some, which would make sense why surging in chop. Inspect your paddlewheel while on the trailer, if you spin it, do it slowly as to not mess you the sensor. You could also pull it to inspect and clean, may have gotten a little debris in it.
    2011 Sea-Doo Wake 155
    Nov 2016
    Knoxville, TN
    0 off could be GPS, but if no puck, you have paddlewheel
    Sep 2017
    Thanks, it's in the water till september...but will pull it out and see come September.
    Worst case I will see if they can replace it under warranty at winterization.
    For now I will just load up the app on my iphone to get it dialed daily!
    2022 SA450
    2019 Mojo
    2017 Mondo - SOLD
    Nov 2016
    Knoxville, TN
    Is it on a lift or actually sitting in the water for the season?
    Sep 2017
    Sits in a slip in the marina...shoulda looked at it last week when I pulled out for mid season oil change!
    2022 SA450
    2019 Mojo
    2017 Mondo - SOLD
    Nov 2016
    Knoxville, TN
    Quote Originally Posted by jcredible View Post
    Have you thought about the Nautic-laugic GPS? It is plug and play into your current system, I had it on my Mojo
