Results 1 to 6 of 6
    Jul 2021
    Calghary
    Post Bus bar under dash corroded
    Only half of the electric circuits are working on my 2018 Mojo, and it appears to be that the +ve Bus bar under the dash is so corroded that the connections are intermittent - I have just ordered a new bus bar to replace my existing one and i will give all the terminals a scrape and clean but.... Has anyone else had corroded bus bar issues? Any ideas why it happens?
    Jan 2021
    Columbus, Ohio
    Similar to any battery terminal connection. It is oxidizing from the humidity in the air and having loose connections. You are already replacing it, good catch.
    I would use battery terminal spray protectant on it once you are done replacing to help reduce this problem. Also, do you put the boat cover on wet? The cover can vent but it traps a bunch of moisture, and takes a long time to fully dry out.
    2015 Moomba Mojo Surf Edition
    4,000lbs
    Manual Flow
    Jul 2021
    Calghary
    Great advice about the spray. I didn’t know there was such a thing.
    I’m pretty careful about not putting it away wet, but I only got the boat this year, so don’t know about the original owner. But, again, thanks for the advice. Appreciated.
    Jan 2021
    Columbus, Ohio
    Quote Originally Posted by RonD View Post
    Not sure about shipping or brands in Canada but this is the amazon link to what I have used in the past.
    https://www.amazon.com/CRC-05046-Bat...06606379&psc=1
    4,000lbs
    Manual Flow
    Jun 2020
    Reno, NV
    Get some buckets of damp-rid too. Set them in when you cover the boat.
    Currently boatless
    2020 SA 450 Wife calls it White Cloud. Said it makes her feel "Classy"
    Jul 2021
    Calghary
    Got the Protection spray and damp rid - just waiting for the new bus bar and I’m good to go.
    Thanks Guys
    2006 Campion 550i Chase - sold
    2018 Moomba Mojo - Big upgrade
Tags for this Thread
