Results 1 to 10 of 12
Thread: Fresh Air Exhaust
04-26-2007, 02:46 PM #1Senior Member
- Aug 2006
- 167
Fresh Air Exhaust
First off, thanks to Pickle311 for planting this seed in my head...now I can't sleep as I have yet another mod idea for the boat bouncing around inside my head
Anyway, check this: http://www.freshairexhaust.com/
My initial reaction was like" if it's so great, why isn't it standard on all boats. Only makes sense to vent under the water vs on top." But I have to admit, the comment about the end of the day headache got me thinking. Plus, the noise reduction is what I originally set out to accomplish.
With all of the waterspots we do, particularly wakesurfing, this seems like a very valid topic for discussion.
Why couldn't a guy go to a muffler shop and have them fab two pieces of pipe about 2' long plus a bracket that mounts directly to the exhaust flap holes? I figure it could do a 90deg turn from the transom, straight down 2', then another 90deg turn outward. Don't see why it has to funnel into just one piece? They wouldn't even have to be connected. That way you're assured no back pressure issues or otherwise...just lengthening the system a litle bit essentially. I think it would look prety bad ass IMHO...like an old hot rod exhaust. Couldn't cost that much and the fab work wouldn't be that hard. What am I missing? THinking about pulling it over to Midas or somewhere this weekend and seeing what they could rig up. Any thoughts???
04-26-2007, 05:07 PM #2
If you look at the underwater video and approximate where the swim platform ends (approx. 2 feet beyond the hull), I see the gas bubbles reaching the surface about 2 feet beyond the swim platform which I don't think you gain anything except for those on or near the swim platform. The double connection is for the torque exerted on the device while in a turn.
04-26-2007, 06:43 PM #3Senior Member
- Oct 2005
- Central FL
- 791
Do you want two 4 inch pipes extending below your waterline creating, drag ? It would slow you down, create a HUGE spray (well, actually 2), and probably come off after any sharp turn.
You have to understand the physics at work here. Lean over the gunwall and stick your hand in the water, now tell someone to hit the throttle... now try to keep your hand in EXACTLY the same place. A simple pipe clamp is NOT going to hold your arm there anymore than it will a 4 inch exhaust pipe.
I'm sure the guys at Midas will do a number on your boat !
-Joe
04-26-2007, 07:07 PM #4Senior Member
- Aug 2006
- 167
Ok, so keep the 2-1 idea...why couldn't something be fab'd for A LOT less $$$. This just seems like such a great idea but the cost benefit just isn't there.
As for Midas (or whomever), they would only bend the pipes and weld a bracket...I would do the install obviously.
04-26-2007, 09:37 PM #5Senior Member
- Sep 2005
- Austin, Tejas
- 491
you also have to keep in mind that the FAE is designed to break away if you hit something rather than transfering the force up to the hull of the boat
04-26-2007, 10:12 PM #6Senior Member
- Dec 2004
- Cinci-Dayton
- 1,014
I have it, I recommend it. If you install yourself I have a few tricks.
I sent them a better mounting design, I dont know if they changed to it.
The headache stuff is real, the noise reduction is nice very nice.
Two pipes must be an IU grad.
Two feet is forever when you are solving a back draft problem. Watch the Coast Guard tape.
Normally I would dissect these issues in detail but I just got home. This was my first addition to the boat well worth it IMHO.
If you search me and FAE I link to a Coast Guard report on CO. Before I saw their film I was, as you will see in my early posts a vocal non-believer.
SD2
04-26-2007, 10:30 PM #7
CO is a huge concern with us - I was skeptical of the design for the reasons given, however, SD2 your testimonial is good and I think this will be our first option. Thanks
04-30-2007, 10:07 AM #8
Centurion Boats have a sideswipe exhaust. Helps with CO when wakesurfing unless you're goofyfoot, then it's shooting the exhaust on your side.
Future option for Moomba???
04-30-2007, 10:14 AM #9Senior Member
- Mar 2005
- t-town
- 718
Originally Posted by sailing217
i would much rather got with the fae over the sidewipe.
just my .02$
06-16-2007, 12:34 PM #10Senior Member
- Aug 2006
- 167
Hey Smokedog~ After 2 weeks of hardcore suring we are ordering the FAE first thing Monday! the CO is absolutely killing us. The Wife said "buy it - now" Just curious if you had any more input to share? How exactly does it mount? What was your design improvement...something I could do when I go to mount? How long to install? Special tools? Has it ever come off or become loose? Really excited to see the difference. Don't see my '04 Mobius LS listed on their site so assume they will have me measure something? Anything else? (as if that's not enough questions) Thanks man!
Marc
Boat Exhaust
By jdsharpe57 in forum Boat OwnersReplies: 22Last Post: 03-06-2008, 01:25 AM -
Group buy on FAE (Fresh Air Exhaust) $75 off!!!
By iaonbb in forum General ChatReplies: 40Last Post: 12-04-2007, 09:16 PM -
Fresh Air Exhaust units
By smokedog2 in forum General ChatReplies: 6Last Post: 12-19-2005, 02:57 PM -
Exhaust flapper size
By sextons in forum Service & RepairReplies: 3Last Post: 09-19-2005, 01:55 PM -
thermostat & no water from exhaust
By VerityBob in forum Service & RepairReplies: 6Last Post: 04-27-2005, 09:16 PM
