Results 11 to 20 of 20
Thread: Vision control issues 21 SL
08-10-2021, 08:29 AM #11
I spoke with my dealer (we usually do things remotely as I prefer to do my own work) and they spoke with skiiers who says it's likely a bad ethernet cable. They are sending me a new one.
In the meantime I got under the dash and unplugged the cable wiggled it a bit and plugged it back in and it seems to be working so far.2020 Supra SA
08-10-2021, 08:42 AM #12
I hope it is that simple for mine as well. What are the chances two ethernet cables are bad on new boats? I have replaced cables at the office after years that have been pinched and twisted etc, but after a couple of months...fingers crossed it is indeed that simple though.
Appreciate the insight. Will mention it to the dealer as well.
21 Supra SL
19 Moomba Max
08-10-2021, 09:10 AM #13
08-10-2021, 09:12 AM #14
If Ethernet cables are anything like phone charging cords, there is a huge variance in cable quality and robustness on the market.
Sent from my iPhone using Tapatalk2021 Supra SA 400
2018 Supra SA 400 (SOLD)
Michigan
08-10-2021, 10:14 AM #15
There have been quite a few issues with the cables that I have seen here and elsewhere on the interwebs.
Hopefully it's that simple of a fix I agree!2020 Supra SA
08-13-2021, 12:13 AM #16
Dealer emailed back today. Ethernet cable replaced. Water testing tomorrow. Hopefully, it works as it should.
21 Supra SL
19 Moomba Max
08-29-2021, 04:54 PM #17
Just closing this thread off. Used the boat for a good 10 hours after replacing the ethernet cable and everything works as it should.
Sent from my SM-G991W using Tapatalk
09-06-2021, 08:32 PM #18
My dealer sent me the cable, it's not a standard Ethernet it's got different ends on it but must be some form of Ethernet.
A bit tight if you have big hands but total time to replace was under 5 minutes.
Solved the screen issues.2020 Supra SA
09-06-2021, 08:34 PM #19
Looks more like a midi cable
Sent from my SM-G781V using Tapatalk2021 Moomba Makai
09-06-2021, 11:12 PM #20
D-coded ethernet.
4 pins = 100Mpbs
X-coded ethernet
8 pins = 1Gbps
They are using industrial grade because they are IP67 rated for water.
But that is neither.....mini sub 5 pin...looks to be something proprietary.2015 Moomba Mojo Surf Edition
4,000lbs
Manual Flow
