Results 1 to 10 of 19
    May 2010
    North Dallas, TX
    Default 2006 Moomba Mobius LSV Starter
    I am in a bind. I am almost positive my starter is bad. Checked battery and connections. Everything works, but won’t turn over. What starter do I need. I have asked multiple online sites that sell marine starters with no reply. Need to get it going before vacation this weekend.
    Thank you!!!
    Jan 2021
    Columbus, Ohio
    Bottom mount? Assault 325? Monson 310?
    Indmar Part# 571006 - this is for both Bakes has it in stock $200
    2015 Moomba Mojo Surf Edition
    4,000lbs
    Manual Flow
    May 2010
    North Dallas, TX
    Jan 2021
    Columbus, Ohio
    Yeah, that is bottom mount. The bolts come up through the bottom of the starter and into the engine block. Its on the port side, correct?
    Its a GM 5.7L 350 based engine. Should be a starter for any 1988-1999 GM pickup truck would work. I'm sure the "marine" version is coated and made for coast guard approval, etc. but in a pitch your local auto parts shop would have it.
    4,000lbs
    Manual Flow
    May 2010
    North Dallas, TX
    Changed out the starter and it still won’t start. I hear a click and nothing else. Battery is good and connections are clean. Any other ideas? I heard a fuse can blow, but I have no idea what those look like or where they are.
    May 2010
    North Dallas, TX
    I found this fuse and pulled it out and it looks good. Open to suggestions.7A138D22-6ABA-4655-8984-B18BFAC00D26.jpg
    Jan 2021
    Columbus, Ohio
    Can you spin the engine by hand?
    Put a breaker bar on 1 of the pulley bolts and try to spin it.
    Teeth missing on the flywheel?
    Starter relay?
    4,000lbs
    Manual Flow
    Aug 2011
    Quote Originally Posted by Holdmybeer View Post
    Starter relay?
    Dead battery..
    2002 Moomba Mobius LSV - Sold
    2006 Moomba Mobius LSV - Sold
    May 2010
    North Dallas, TX
    Changed battery over and still just gives one click when I try and start it. Doesn’t turn over at all.
    I have no idea how to spin the engine. I’ll start YouTubing. This one has me stumped.
    Jan 2021
    Columbus, Ohio
    If it is clicking then the ignition relay is pulling it but not the starter relay.
    Check all the breakers and fuses.
    Ignition relay pulls in starter relay and starter powers and spins. Something is not closing and passing power. Do you have a volt meter or test light?
    4,000lbs
    Manual Flow
