Results 1 to 10 of 22
Thread: Fuel ussage
04-26-2007, 06:05 AM #1
Fuel ussage
What will be the average fuel consumption an hour of an 07 LSV with standard 325 hp engine when skieing and wakeboarding.
Wakeboarding, no ballast, 3 people in the boat, boarder about 80 kg.
Skieing: Same setup.
What are you experience with fuel ussage, how many hours till the tank is empty, and what wil it consume when cruising for say 5 mph?
My last boat had an fuel consumption meter. Now i have to gues what my friend should pay me when going out on the lake. What are your methodes of calculating fuelcosts?
I don't want to rip them off but also don't want to rip myself off
04-26-2007, 07:01 AM #2Senior Member
- Dec 2004
- Cinci-Dayton
- 1,014
SWAG 1st part 5gph.
2nd I don't know.
04-26-2007, 02:49 PM #3Originally Posted by smokedog2
So 5 gph is 18(liter)ph is average for skieeing and boarding.
04-26-2007, 03:35 PM #4
I always fill up on the way back in from the lake. Of course, that means when we leave to go to the lake, tank is full. I make those that go split the cost based on how much it takes to fill it back up. Generally no bickering.
Hope this helps
B
04-26-2007, 04:16 PM #5Originally Posted by Buttafewcoe
Just curious what moomba owners think of ther fuel ussage?
My old Rinker with an 4.3l V6 engine did around 20 liter an hour when skieing. I added an fuel flow meter but because of the mpi engine this is not possible now.
So you think 5 gph?
FYI:
A gallon of gas cost around here $ 8,20! But this is Europe, skieing is only for the filthy rich
04-26-2007, 04:27 PM #6Senior Member
- Mar 2005
- t-town
- 718
with my 325 i would say i average overall anywhere between 4-6 gallons per hour. that would include boarding, surfing and cruising around.
gas here jumped from 2.63 to 2.79 a gallon
04-26-2007, 05:03 PM #7Originally Posted by qb12
04-26-2007, 09:10 PM #8Senior Member
- Aug 2006
- Millington TN
- 204
If your engine is a 2007 model 325, you should be able to install a fuel flow meter. It would need to go between the fuel pump and the fuel rail. This should give you an accurate reading because the newer engines like yours do not have a fuel return from the fuel rail back to the tank. We have moved the fuel pressure regulator from the fuel rail to the fuel pump bracket. We still return from the pump bracket to the tank but we no longer return from the fuel rail. Just make sure that the flow meter can withstand the 60 psi fuel pressure that the fuel pump produces.
By the way, I havent seen anyone define SWAG for you. It stands for Scientific Wild _ss Guess.
Engine Nut
Originally Posted by mvd
04-26-2007, 10:22 PM #9Senior Member
- Dec 2004
- Cinci-Dayton
- 1,014
a Wag is simply a Wild _ss Guess, they are never to be trusted!
04-27-2007, 05:31 AM #10
[quote="Engine Nut"]If your engine is a 2007 model 325, you should be able to install a fuel flow meter. It would need to go between the fuel pump and the fuel rail. This should give you an accurate reading because the newer engines like yours do not have a fuel return from the fuel rail back to the tank. We have moved the fuel pressure regulator from the fuel rail to the fuel pump bracket. We still return from the pump bracket to the tank but we no longer return from the fuel rail. Just make sure that the flow meter can withstand the 60 psi fuel pressure that the fuel pump produces.[quote]
This is good news!!! I thought that there was an returnline so an flowmeter is not possible. So what will be the best way to place the sensor?
I found:
Navman Fuel 2100
Lowrance LMF-200 with sensor EP-10
Faria Fuel manager
But i cant find the pressure they can handle. I assume the minmal pressure is 60 psi? Is that the maxium possible pressure in the fuelsystem?
If anyone can help me with the specs of these meters?
Any advise is welcome
A
Fuel Filter?? Lack of power on fuel throttle
By slalomskier in forum Service & RepairReplies: 8Last Post: 08-02-2007, 03:52 AM -
replace fuel filter with fuel water separator
By vansolo in forum Service & RepairReplies: 4Last Post: 05-04-2007, 12:17 AM -
Fuel Tax Refund for Boat Fuel
By Will Watters in forum Boat OwnersReplies: 10Last Post: 05-03-2006, 01:14 AM -
MPH, Fuel Gauge
By wakesurfer1 in forum Sales & InformationReplies: 2Last Post: 05-06-2005, 04:56 PM -
Fuel
By Bammer in forum Boat OwnersReplies: 3Last Post: 11-26-2002, 09:57 PM
