07-19-2021, 06:29 PM #1Junior Member
- Jun 2020
- 13
96 PCM 351 ignition parts - where to get?
The 351 PCM in my 96 Boomerang has a screw on Prestolite distributor with what appears to be an electronic conversion inside (see pics). I need a new distributor cap and the guts inside the distributor including the electronic ignition set and the timing advance mechanism. NAPA is not able to find replacements (they show the Prestolite as no longer available). Any suggestions where I can go to find replacement parts or a new system? Thanks in advance. Kevin
Dist parts angle.jpgDist cap off.jpgDist parts advance.jpgDist empty.jpgDist parts down.jpg
07-19-2021, 07:04 PM #2
Can you convert it via MSD or similar, digital system.
Check out these guys. Might be able to help.
https://aaamarine.com/marine-electro...n-distributors2015 Moomba Mojo Surf Edition
4,000lbs
Manual Flow
07-19-2021, 11:36 PM #3Junior Member
- Jun 2020
- 13
thanks HMB!
07-20-2021, 10:41 AM #4Senior Member
- Sep 2005
- Claytor Lake, VA
- 598
Check with these guys. https://skidim.com/engine/electrical...n-modules.html
2005 Mobius LSV
325 EFI
