Page 1 of 9 123 ... LastLast
Results 1 to 10 of 87
    May 2018
    Default 400 with 1.76 transmission prop choices
    I know the prop options in 2020 for the 400/1.76 was a 16x17 and 16x15, looks like there is a new option 16x13.9
    Anyone running the ACME 3591 16x13.9? Sounds like an absolute stump puller.
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    Crosby TX
    That’s what I’m running on my SE
    Aug 2020
    Middle Tennessee
    I run the 16x15 on my 400 with 1.76 and it does fine fully loaded and tops out at 38.
    The 13.9 assuming the same prop slip would only drop the top speed to 35 and would likely be significantly torquier down low.
    Seems like a good option to me.
    2020 Supra SA
    May 2018
    35 top speed is plenty, I will order the 16x13.9
    The fastest I go is wakeboard speeds 22-23mph
    2021 Supra SA 400
    Michigan
    Aug 2017
    I have the 16x15, and have considered trying the 16x17. There are no issues launching, but the rpms are a little higher at surf and wakeboard speeds. Anything taller would be nuts.
    2019 Supra SL450
    May 2018
    Quote Originally Posted by Shoebox View Post
    What RPM does the 16x15 give at wake and surf speeds?
    2021 Supra SA 400
    Michigan
    Aug 2017
    Full ballast surfing 11.2-11.4 I'm about 3700-3800 rpm, with lead and maybe a little water ballast at 22 is about the same. I do have the 450 though.
    2019 Supra SL450
    Aug 2020
    Middle Tennessee
    @Shoebox what's your drive ratio?
    I'm 1.76 : 1 and run about 3200-3400 at surf speed on the 16x15 prop full ballast
    2020 Supra SA
    Commerce Lake, MI
    That’s nice and low for Rpm’s
    2017 Moomba Craz
    May 2018
    Quote Originally Posted by SONIC View Post
    Curious how much RPM would increase with the 16x13.9?
    2021 Supra SA 400
    Michigan
