Results 1 to 10 of 12
    Dec 2006
    Tigard, Oregon
    Default Re-arranged Gauges
    I re-arranged my gauges tonight based on what made the most sense to me. Results below. I only had to cut and re-splice three wires which I didn't think was too bad considering that I moved 4 of the 6 small gauges.
    Al
    Al
    Mar 2003
    Springfield Missouri
    Yep, good move. Is SC still putting the depth gauge on the side? Switching the voltmeter with the depth gauge was one of the first things I did on my '98. At least your depth gauge matches the rest of the guages. Mine was probably an aftermarket on that year. I can't imagine hitting bottom because one was looking ahead instead of looking down at the throttle.
    "Yeah, but when I hit bottom my alternator was putting out a good 14 volts".
    Dec 2006
    Tigard, Oregon
    zabooda,
    Stock configuration of the secondary gauges was:
    Left side - Voltmeter on the left, oil pressure on the right
    Right side - left to right: Temp, Fuel, Depth gauge
    Above throttle - wakeplate position gauge
    Yeah, always looking down by the throttle to look at the wakeplate position was not ideal (to put it nicely).
    I also wanted to switch the fuel and depth gauges but it entailed a lot of work for not much gain so I didn't do it. It's close enough.
    Al
    Al
    Oct 2005
    No idea who makes them. Got mine from the dealer. Switched with the voltmeter as well.
    Mar 2003
    Good to see the depth guage on the front console. Poor voltmeter never gets any respect and always the guage that is moved.
    Dec 2006
    Baltimore, Maryland
    Default Gauges
    cab13367
    I will be picking up my new XLV this Sunday or the first of next week. I would like to make the same guage changes you've done. Can the entire instrument panel come out to make it easy to work on or do you need to stand on your head to get behind the panel? Any insight or techniques to making the gauge switch would be helpful.
    Thanks Richard
    Mar 2005
    t-town
    Quote Originally Posted by Ed G
    Nice.
    With my lake levels constantly falling, I gotta get a depth guage.
    Any idea who makes 'em for Skiers Choice?
    ed, when i had my outback, i installed a hummingbird with the puck transducer and it worked great. The install was pretty simply and i drilled a new whole in the dash for it.
    Cab, great job. I would like to do what you have done. I can't stand always looking down to see where i have the wakeplate.
    db
    Dec 2006
    Tigard, Oregon
    Richard,
    I am sure that you can remove the entire dash but I don't know that it would necessarily make the job any easier. It's actually not that bad. First thing I did was to remove the driver's seat (easy, 4 screws and 4 nuts on my 06) which makes it a lot easier to access. You will see that they've got zip ties all over the place keeping all the wires secured. I looked at the gauges I was going to move and started snipping all the zip ties that were in the way (nice, sharp wire cutters helps, careful not to accidentally snip any wires). Each gauge (except for the depth gauge which was hard wired) has a connector that you can disconnect and two nuts holding the gauge in place, so it makes it easy to disconnect and push the gauge out the front. I labled each half of the connectors with a Sharpie, disconnected and removed the gauges, and re-installed them where I wanted them. I then moved the appropriate connector to the new gauge position and only snipped the wires that I had to. Most of the wires were long enough to reach the new locations so I only had to snip and reconnect three wires. Trace the wire the you need to snip towards the new location and you will easily see where you need to re-splice it in.
    Hope that helps.
    Al
    Al
    Dec 2006
    Baltimore, Maryland
    Default Gauges
    Thanks Al for the detailed directions. I just hope mine goes as smoothly as yours did. When I placed the order for the boat I tried to get the dealer to ask the SC to make the gauge locations changes I wanted but was told the panels are pre-assembled and SC would not make the change. So now it's my turn to give it a try.
    Thanks again Al
    Richard
    Dec 2006
    Tigard, Oregon
    No problem. Just take your time and I'm sure you'll have no problems.
    And congrats on the new boat.
    Al
    Al
  1. All gauges quit
    By BensonWdby in forum Service & Repair
    Last Post: 03-15-2010, 11:24 PM
  2. all my gauges just quit
    By yzblue125 in forum Service & Repair
    Last Post: 06-08-2006, 03:06 PM
  3. Instrument Gauges
    By hammons0814 in forum Service & Repair
    Last Post: 09-13-2004, 12:02 AM
  4. Speedometers/Gauges
    By mikeoc in forum Boat Owners
    Last Post: 06-26-2003, 09:06 PM
  5. Beede Gauges
    By Retirement Fund in forum General Chat
    Last Post: 02-13-2003, 01:35 PM
