Results 1 to 5 of 5
    Jul 2021
    Default Best surf setup for 17 mondo
    Looking for ideas for getting the best surf wave out of our 17 mondo
    Has 2.0 flow system, upgraded 910 rear bags. Iím 6í2 205 and having a hard time getting off the rope. Any recommendations/ ideas would be appreciated.
    Mar 2021
    I have a 19 mondo and can surf it no problem. I have the 750's in the back and 500lbs of lead. I a guessing its your board or where you are trying to surf. I am 6' 200lbs and like i said, no issues without a rope for as long as i want to ride.
    Try this setup, 100 ballast on surf side, 80% on non surf side and only 70% in front. Make sure your wake plate is up at 20% or less while underway and try to stay closer to the middle behind the boat not way out to the side.
    Sep 2017
    Here is my old setup:
    1) 1140s in the back(although they probably only got 900 lbs of water in them.)
    2) 500 lbs of lead on surf side.(usually under seats midship)
    3) 1000 lbs up front.(500 +500 IBS)
    4) Regular
    a. 10.8-11
    b. Everything 100% full
    5)Goofy
    a. Sped up to 11.3-11.5
    b. usually would run non surf side at 80% to list the boat more
    If I had a light crew of less than 5 people...we would take the old 650 lbs from the back and put it on the floor infront of rear seat.(That made it pop with light crew)
    2019 Mojo
    2017 Mondo - SOLD
    colorado
    Quote Originally Posted by Jason1975 View Post
    I have a 19 mondo also. We often use a similar setup as Jason.
    when we run a small crew, with 3-4 people, we may load up a bit more.
    I have 500 lead that is 250 each side under bags. have 900# bags in lockers. in the bow we have the bow filler bag also. we also have a 500# bag that we put on the floor in front of the rear seat.
    we do not load everything full. but we will load the 500# bag then surf side locker will be about 60-90%. non surf side will be about 30-60%. bow will be about 70%. surf speed will be between 9.8 and 10.8. WP is usually 0-15%. I do not use the autowake, i occasionally check the pitch and roll for reference.
    i am 6'-2 and 200#. i surf a phase 5 diamond (not sure of the size, but i am a little big for it and i occasionally struggle to stay in). also a doomswell nubstep. and the go to broadcast for the days when just cruising, or carrying littles with to get them a surf experience.
    19 Mondo
    08 LSV, forever loved
    Mar 2021
    I forgot to mention two things.. Usually only my wife and 11 yr old son in the boat so a small crew, and i run at 9.6 mph and the wave is quite nice. I wouldn't say its long but i can move up and back about 6' so its not too bad. the first year i got the boat, everyone said 10.6 mph to 11.2.. that was just too fast for my boat and the wave didn't have alot of power. I slowed down to 9.6 and no just about anyone can surf my boat with a small crew.
    I am sure there are things i could be doing better to make the wave even better. I do NOT use autowake mainly because i don't know how and didn't want to read the 33 pages of posts. I go by feel and look of the wave.
Tags for this Thread
