04-23-2007, 06:50 PM #1Senior Member
- Aug 2005
- 134
water gushing from engine-Help!!!
I put the boat in today to run it and check for leaks-If you were facing the back of the boat towards the lower left half of the engine I find this loose cap or plug like the size of a golf ball that seemed to fill this empty hole-no threads-like a little dish,brass or gold in color and the outer part is black maybe because this was the end in the engine holding in the water-anyway when the engine is on water starts pouring out of this hole-thank god we didnt just go riding without checking everything-this was a good lesson to check everything while on the trailer.
The opening is blocked by an engine mount bracket. How else can I get to it ?. I think this might of been leaking for a while and now it finally popped out completely-it seems like if I could get to it I could easily put it back. Anyone have this happen??? or know what it is-I am going to the Marina tommorow . Is it a flushing plug? help!!!!
04-23-2007, 07:14 PM #2Senior Member
- Sep 2005
- Austin, Tejas
- 491
sounds like a freeze plug that goes in the block, but I thought those were only in ford engines, not Chevys. Maybe it's something that was added for marine.
04-23-2007, 08:57 PM #3Senior Member
- Aug 2006
- Millington TN
- 204
Re: water gushing from engine-Help!!!
Originally Posted by LSV04
At any rate, have your dealer reinstall the plug and run the engine to check for external leaks. Also after it has run for a while, check for water in the oil from an internal leak. If there is an internal leak, the oil will be "milky". If you have no internal or external leaks you should be OK.
Good Luck!
Engine Nut
04-23-2007, 09:06 PM #4Senior Member
- Aug 2005
- 134
engine block
Thanks for all the info-at least now I know what I am getting into. Do they pop out due to the freeze. I had it fogged and thought they put anti freeze in. I didnt see water coming out anywhere else and I will check the oil now. I have major problems if something cracked. Thanks for your help.
cranking engine out of water
By hwb06 in forum General ChatReplies: 6Last Post: 04-10-2007, 07:49 PM -
water in the engine compartment
By Zihuatanejo in forum General ChatReplies: 1Last Post: 04-28-2005, 08:12 AM -
Saltwater brackish water engine care
By chpprpilot in forum General ChatReplies: 5Last Post: 04-12-2005, 03:52 PM -
Engine bog down
By Yellowmobius in forum General ChatReplies: 2Last Post: 07-28-2003, 02:45 PM -
Salt Water/Brackish Water Use
By RickMcD in forum General ChatReplies: 2Last Post: 06-28-2003, 11:59 PM
