Other things to check:
Engine starting circuit requires the coolant temp switch to be good also. If you lost 1 or both of them, engine will not start.
Oil level is also a sensor that will not allow the boat to start.
Either one of these could have went bad and the reason the fuel pump won't prime.
2015 Moomba Mojo Surf Edition
4,000lbs
Manual Flow
