Page 4 of 4 FirstFirst ... 234
Results 31 to 38 of 38
  1. #31
    May 2018
    Quote Originally Posted by UNSTUCK View Post
    Why make those claims then?
    I think you thought I was calling out the side shift as not be aggressive or not enough thrust. I was referring to wakeboat thrusters in general.
    Just helping set expectations of how aggressive thrusters are in general.
    I really like the sideshift kit and would get it if I wanted thrusters.
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
  2. #32
    UNSTUCK, you would need to use that switch to drive a relay. The relay would have to be spec'd to handle the 180+ amps. That 20 amp switch alone won't last long if it's really peaking 300 amps and running at 180.
    In my conversation with Sideshift today, I learned a bit more and am more interested now. Their "WB230" system peaks at 300 starting amps and drops to 180 running amps. That's about 2.5 HP for 100 pounds of thrust. This is consistent with what I'm seeing for other brands marketing our boats. They range from 75 to 110 pounds of thrust, but you could needlessly go as big as you want. Max run time is 30 seconds with a "10 second cool down" following that. I wonder if that's not a typo though and should be 10 minutes?
    I was quoted $2695.00 for this system, excluding the joystick, key fob and receiver. A simple on-off-on momentary switch is all that's needed to supply 12 volts to either side of the motor controller. This could make controlling it really customizable to your liking. Something like this would work fine though:
    https://www.amazon.com/U-S-Solid-Ope...271133&sr=8-31
    It's temping for sure.
    2019 SUPRA SE 450
    2015 Tige Z1 (SOLD)
    2014 Tige Z1 (SOLD)
    2012 Yamaha 212SS (SOLD)
    2008 Yamaha AR210 (SOLD)
  3. #33
    Dec 2020
    Atlanta, GA
    I have to admit I'm surprised it has the open propeller blade. I can imagine someone irresponsible coming back to get a downed surfer and they put their leg in that thing. Ouch! Most of the others I've seen are in a tunnel with a grate preventing the "circular" saw blade
    Current Boat: 2021 Moomba MAX, 400 Raptor, G6 Ballast
    Prior Boats:
    2015 Nautique G21
    2012 Mastercraft X45
    2010 Mastercraft X14V
    2005 Sea Ray 220SEL
    1986 Mastercraft 190
  4. #34
    Dec 2016
    Quote Originally Posted by trace View Post
    That’s what the motor controller is. Box of relays.
  5. #35
    Dec 2016
    I was.
    And this is a sentence to make my post long enough.
  6. #36
    Whoops, my bad. I missed you were keeping the controller box. Good call.
    2019 SUPRA SE 450
    2015 Tige Z1 (SOLD)
    2014 Tige Z1 (SOLD)
  7. #37
    May 2018
    Waynesville, Ohio
    Quote Originally Posted by cpropes2005 View Post
    Haha, yeah had shopped the other brands for a while but couldn't bring myself to do it for those prices. This one came along and dropped just below my "screw it click the buy button" threshold.
    Any new updates or feedback from this system? I am highly considering a thruster kit. My only experience is being on a G23 for a weekend with thrusters. Now I need them.
    2018 Moomba Craz
    6.2L Raptor 400
    6 Pump Ballast, Autowake 2.0, Flow 2.0 Surf System
    OJ 15x13 Wake Prop
    Digital Cruise Pro 3 (paddle wheel)
    Wetsounds Rev 10's
    2005 Supra Launch 22SSV - Sold
  8. #38
    Oct 2010
    Bump, has anybody else added these?
