Results 11 to 20 of 38
  1. #11
    Oct 2018
    Hockley, Tx
    Is the motor variable speed? If so how is the speed adjusted?
    2019 Makai
    Raptor 450 w/ 1.76 Trans
    WakeMakers 1350s in the rear & 1K in Lead
  2. #12
    Apr 2015
    Quote Originally Posted by TXSurf4 View Post
    No, single speed. If I want to make small adjustments I just bump it for a second or two vs holding it for an extended burst to get the boat to swing all of the way around.
    2015 Mojo with autoflow
  3. #13
    May 2017
    Alberta, Canada
    Any noticeable changes to your wave shape? Seems like it might put some oddball drag/cavitation into the wave face?
    2021 Mojo, 6.2L Raptor 400/1.76, Acme 3407 15.5x13, G6, Flow3, +6500 lbs ballast
    2005 Mobius LSV (sold)
    Windermere Lake, B.C., 2800' Elevation
    2021 Mojo Mods
  4. #14
    Aug 2020
    Middle Tennessee
    Quote Originally Posted by Hayden View Post
    Shouldn't it's always above the wake plate so shouldn't really even be in the water once you're moving.
    I too haven't seen it on the plate, I like it though Simple!
    2020 Supra SA
  5. #15
    Mar 2021
    South Georgia
    I like that too. As a matter of fact, I may just have to do that. That is less than half the cost of the EZ thrusters when I called to get pricing from them. And I honestly like the idea of not drilling holes in the transom. Or as few as possible anyway.
    2021 Moomba Makai
  6. #16
    May 2018
    I like that install, I would want that joystick next to throttle.
    Does that thruster operate at all speeds?
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
  7. #17
    Dec 2016
    I like it! I'm wondering about the joy stick controller though. Seems like it would be difficult to operate it and the throttle at the same time. Is the joystick just a momentary on-off-on switch? I wonder if you could get a Supra throttle and be able to use the twist function? Or swap in a Tige throttle and use the built in momentary switch for the TAPS plate. No idea if the throttles are compatible, but my guess is they could be made to work if not a direct swap.
  8. #18
    Apr 2015
    Quote Originally Posted by UNSTUCK View Post
    Was worried about the same thing but in practice it has become natural to move my hand back and forth. Definitely would say putting it as close to the throttle as possible is a plus. Actually wanted to put it on the the angled surface on the front of the arm rest but there is not enough room for the backing plates behind it.
  9. #19
    Apr 2015
    No, no effect on the wake. Like Sonic said it’s basically out of the water at speed.
  10. #20
    Aug 2020
    Middle Tennessee
    Here's a link. They ae showing it on the plate on their website as well:
    https://shop-us.sideshift.com/collec...stern-thruster
    2020 Supra SA
