Results 11 to 20 of 38
Thread: Makai thruster install
06-08-2021, 11:02 AM #11
Is the motor variable speed? If so how is the speed adjusted?
2019 Makai
Raptor 450 w/ 1.76 Trans
06-08-2021, 11:22 AM #12Senior Member
- Apr 2015
- 169
06-08-2021, 12:02 PM #13
Any noticeable changes to your wave shape? Seems like it might put some oddball drag/cavitation into the wave face?
2021 Mojo, 6.2L Raptor 400/1.76, Acme 3407 15.5x13, G6, Flow3, +6500 lbs ballast
2005 Mobius LSV (sold)
Windermere Lake, B.C., 2800' Elevation
2021 Mojo Mods
06-08-2021, 12:40 PM #14
06-08-2021, 02:28 PM #15
I like that too. As a matter of fact, I may just have to do that. That is less than half the cost of the EZ thrusters when I called to get pricing from them. And I honestly like the idea of not drilling holes in the transom. Or as few as possible anyway.
Sent from my moto z4 using Tapatalk2021 Moomba Makai
06-08-2021, 02:50 PM #16
I like that install, I would want that joystick next to throttle.
Does that thruster operate at all speeds?
2018 Supra SA 400 (SOLD)
Michigan
06-08-2021, 04:07 PM #17Senior Member
- Dec 2016
- 128
I like it! I'm wondering about the joy stick controller though. Seems like it would be difficult to operate it and the throttle at the same time. Is the joystick just a momentary on-off-on switch? I wonder if you could get a Supra throttle and be able to use the twist function? Or swap in a Tige throttle and use the built in momentary switch for the TAPS plate. No idea if the throttles are compatible, but my guess is they could be made to work if not a direct swap.
06-08-2021, 05:56 PM #18Senior Member
- Apr 2015
- 169
Was worried about the same thing but in practice it has become natural to move my hand back and forth. Definitely would say putting it as close to the throttle as possible is a plus. Actually wanted to put it on the the angled surface on the front of the arm rest but there is not enough room for the backing plates behind it.
Sent from my iPhone using Tapatalk2015 Mojo with autoflow
06-08-2021, 05:58 PM #19Senior Member
- Apr 2015
- 169
06-09-2021, 08:05 AM #20
Here's a link. They ae showing it on the plate on their website as well:
https://shop-us.sideshift.com/collec...stern-thruster2020 Supra SA
