Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Jan 2021
    Columbus, Ohio
    Default Help please....have a couple issues
    Well I have a problem and looking for some help.
    Madien voyage this year I took on a little water didn't think anything of it. Found the air vents of my ibs were open and some water came out.
    Day 2- no ballast leaks same amount of water but kids were in and out and we were surfing.
    Day 3- water again, again surfing. Maybe 1 gallon or 2 on the water for 7hrs, more than day 2.
    Day 4 kids everywhere took some water over the bow. In and out doing sports again 7hrs on water. Bilge never ran but maybe 3 gallons. Checked rear and saw some water around the rudder box.
    Check tonight....rudder wobbles and I can hear water/grease mix slop.
    How hard of a job? What parts and where to get parts? Is this rebuildable or replaced?
    Also found the brackets that hold the raw water pump are lose but the bolts are tight. Are they lose on purpose for vibration?
    2015 Moomba Mojo Surf Edition
    4,000lbs
    Manual Flow
    Jan 2021
    Columbus, Ohio
    Found the whole rudder assembly online.
    There has to be a rebuild kit.
    https://waterskis.com/supra-moomba-rudder-assembly-203/
    4,000lbs
    Manual Flow
    Jun 2020
    Reno, NV
    Sounds like warrantee work. Contact your service center.
    2020 SA 450 Wife calls it White Cloud. Said it makes her feel "Classy"
    Mar 2021
    South Georgia
    This guy seems like he has your same issues
    DIY How to Rebuild a Boat Rudder
    YouTube · Bullshitkorner
    Jul 28, 2012
    https://www.google.com/url?sa=t&sour...=1623115022944
    2021 Moomba Makai
    Jan 2021
    Columbus, Ohio
    Quote Originally Posted by 2in2out View Post
    Warranty from 2015? If that is true then I will contact a dealer but I'm not the first owner.
    4,000lbs
    Manual Flow
    Jan 2021
    Columbus, Ohio
    Jul 28, 2012
    I watched that video. Looks like a 2hr job but no idea where to get parts or if they make a rebuild kit.
    4,000lbs
    Manual Flow
    Jun 2020
    Reno, NV
    My bad, I got you confused with another member of the forum. I thought you had a new Makai.
    Henderson, NV
    if it was me, worst case you are out $400 for the new rudder if that's the issue so that being said, I would yank it apart and head down to the local boat shop and talk to the service guys. doesn't have to be a skiers dealer. any reputable repair shop should have worked on inboards. ask them what they see and where to get parts. you might get a contact for parts OR they might suggest for $xx, they rebuild or order parts and sell to you. with as busy as they all are right now, I would be surprised if any balk at helping knowing they have more business than they can support so ordering the rebuild parts from them and diy are saving them some time and making them a few $$.
    if you get apart and that's not the issue it'll at least take that off the table.
    you sure it's not coming from the shaft seal? can't say in all the years on here that I have read about many rebuilding rudder boxes/shafts. shaft seals are much more common to leak and water could be pooling around the rudder box?
    either way good luck.
    Jan 2021
    Columbus, Ohio
    After an evening of searching, I'm not.finding anything for rebuild. Your suggestion is more than likely my route.
    I thought shaft seal first but nothing around the dripless. Had the wife drive while I carefully inspected.
    The rudder is wobbling. Looking at videos I would call it excessive but not horrible. I actually saw and heard water-grease mix come out around the rudder shaft.
    4,000lbs
    Manual Flow
    Dec 2020
    Boone NC
    Im not sure about the rudder however 1-3 gallons of water after a full day of water sports doesn't sound to concerning to me? I mean until the bilge kicks in I wouldn't even think twice about it... Am I wrong?
    Josh
    2021 Mojo, Sold 7/15/22
    2023 Supreme S240, on order
