Results 1 to 7 of 7
Thread: Depth Finder - Incomplete data
04-22-2007, 01:04 PM #1Junior Member
- Aug 2006
- 16
Took the boat out this weekend and I'm getting the "- - -" for incomplete data on the depth finder. Sometimes if we stop the depth will come up, then go back to the "- - -" like it can't read the bottom. We were only in 12-15 feet of water. Even when sitting at the dock in 5 feet it won't work sometimes. We're in a sand bottom lake.
By the way....it's a 2007 Outback V with only 5 hours on it.
Any ideas?
Craig
04-22-2007, 04:08 PM #2Senior Member
- Feb 2006
- Fayetteville, GA
- 319
If its a shoot-thru-the-hull, sounds like bubbles in the resin holding the sounder to the hull or a loose sounder (same problem, same fix).
04-22-2007, 05:38 PM #3Junior Member
- Aug 2006
- 16
I took the compartment cover off that covers the V-drive. Is the sounder about 3 inches in diameter and looks sort of like a hockey puck with a wire attached?
If so, mine is just sliding around in the v-drive compartment. It has a hard resin on the back and it used to be attached somewhere, but there is a little water in the compartment, and it detached from somewhere in there.
Craig
04-22-2007, 10:18 PM #4Senior Member
- Feb 2006
- Fayetteville, GA
- 319
Originally Posted by cmathis
Yup, hockey puck and should be attached to the hull, normally in front of the prop, and out of line of travel from anything that will cause a disturbance in the water (intakes, fins) and pointed straight down.
When you take it to the dealer for the 15-20 hour break in followup, ask em to stick it on tight this time for ya.
04-22-2007, 11:39 PM #5Junior Member
- Aug 2006
- 16
Sounds good. I'll get them to fix it when I take it in for the first maintenance.
Thanks again Wolf!
Craig
04-23-2007, 04:54 PM #6
Same problem here.
I dont like this type of depthfinder. It givess a lot of ----, no memory function. Is it posible to install another brand of depthfinder without chaning the transducer? I will check the transducer if its installed correct.
Best is to install an thru-hull transducer, very accurate!
04-26-2007, 03:51 AM #7
Same problem here. The hockeypuck is loose in the bilge.
I assume this is a common problem with the Moomba's?
How should i glue this to the bottom?
What is the brand of this depthfinder? Can i use the transducer with another brand of depthfinder. This because i dislike the no memory of the standard depthfinder
Depth Finder
By jroberts in forum Service & RepairReplies: 3Last Post: 07-17-2007, 12:22 AM -
depth finder help!!
By hwb06 in forum General ChatReplies: 1Last Post: 03-26-2007, 11:33 AM -
depth finder
By bamwakeboarder in forum Service & RepairReplies: 3Last Post: 03-19-2007, 09:49 PM -
Depth Finder
By pickle311 in forum General ChatReplies: 15Last Post: 11-22-2005, 05:34 PM -
depth finder
By qb12 in forum General ChatReplies: 13Last Post: 04-01-2005, 10:07 AM
